- Automation Suite on Linux Release Notes
- Automation Suite on EKS/AKS Release Notes
- Automation Suite on OpenShift release notes
2.2510.4+patch2
2.2510.4+patch2 release notes for Automation Suite on EKS/AKS.
Release date: October 23, 2026
About this patch
This release applies a patch to Automation Suite 2.2510.4. The patch addresses some issues in Identity and Insights. For more details, refer to the individual product release notes referenced in the Product versions section.
This patch also includes the following fixes:
- We fixed an issue that caused interactive sign-in with UiPath CLI (
uip login) to fail with the "No tenants found for this organization" error. The issue occurred because the access token issued to UiPath CLI did not include the permissions required to retrieve the organization's tenants.
These fixes will also be included in all future releases starting with Automation Suite 2.2510.5.
How to apply the patch
To apply this patch, follow the instructions in Applying a patch.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
The following table outlines the release status, version, and release notes for all UiPath products deployed under Automation Suite 2.2510.4+patch2.
Legend:
✅ New: This Automation Suite version includes a new product version. New release notes are available.
◆ Bundled: This flavor includes a previously released product version. No new release notes are available.
| Product | Version | Release notes |
| Action Center | ◆ Bundled: N/A | N/A |
| Agents | ◆ Bundled: N/A | N/A |
| AI Center | ◆ Bundled: N/A | N/A |
| AI Computer Vision | ◆ Bundled: N/A | N/A |
| Apps | ◆ Bundled: N/A | N/A |
| Automation Hub | ◆ Bundled: N/A | N/A |
| Automation Ops | ◆ Bundled: N/A | N/A |
| Autopilot for Everyone | ◆ Bundled: N/A | N/A |
| Data Service | ◆ Bundled: N/A | N/A |
| Document Understanding | ◆ Bundled: N/A | N/A |
| Healing Agent | ◆ Bundled: N/A | N/A |
| Insights | ✅ New: 2.2510.4-patch2 | Insights release notes |
| Integration Service | ◆ Bundled: N/A | N/A |
| Maestro | ◆ Bundled: N/A | N/A |
| Orchestrator | ◆ Bundled: N/A | N/A |
| Process Mining | ◆ Bundled: N/A | N/A |
| Screenplay | ◆ Bundled: N/A | N/A |
| Solutions | ◆ Bundled: N/A | N/A |
| Studio Web | ◆ Bundled: N/A | N/A |
| Test Manager | ◆ Bundled: N/A | N/A |
Internal third-party component versions
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
This Automation Suite release bundles the following internal components:
| Component | Version |
| Istio | 1.30.3 |
| ArgoCD | 3.5.0 |
| Prometheus | 3.13.2 |
| Grafana | 13.1.3 |
| Fluentd and Fluent-bit | logging-operator: 6.7.0 fluent/fluent-bit: 5.0.9 |
| Gatekeeper | 3.22.2 |
| Cert-Manager | 1.20.3 |
| Velero | 12.0.3 |
