- Automation Suite on Linux Release Notes
- Automation Suite on EKS/AKS Release Notes
- Automation Suite on OpenShift release notes
2.2510.4+patch1
2.2510.4+patch1 release notes for Automation Suite on EKS/AKS.
Release date: October 7, 2026
About this patch
This release applies a patch to Automation Suite 2.2510.4. The patch addresses some issues in Apps and Integration Service. For more details, refer to the individual product release notes referenced in the Product versions section.
These fixes will also be included in all future releases starting with Automation Suite 2.2510.5.
How to apply the patch
To apply this patch, follow the instructions in Applying a patch.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
The following table outlines the release status, version, and release notes for all UiPath products deployed under Automation Suite 2.2510.4+patch1.
Legend:
✅ New: This Automation Suite version includes a new product version. New release notes are available.
◆ Bundled: This flavor includes a previously released product version. No new release notes are available.
| Product | Version | Release notes |
| Action Center | ◆ Bundled: N/A | N/A |
| Agents | ◆ Bundled: N/A | N/A |
| AI Center | ◆ Bundled: N/A | N/A |
| AI Computer Vision | ◆ Bundled: N/A | N/A |
| Apps | ✅ New: 2.2510.4-patch1 | Apps release notes |
| Automation Hub | ◆ Bundled: N/A | N/A |
| Automation Ops | ◆ Bundled: N/A | N/A |
| Autopilot for Everyone | ◆ Bundled: N/A | N/A |
| Data Service | ◆ Bundled: N/A | N/A |
| Document Understanding | ◆ Bundled: N/A | N/A |
| Healing Agent | ◆ Bundled: N/A | N/A |
| Insights | ◆ Bundled: N/A | N/A |
| Integration Service | ✅ New: 2.2510.4-patch1 | Integration Service release notes |
| Maestro | ◆ Bundled: N/A | N/A |
| Orchestrator | ◆ Bundled: N/A | N/A |
| Process Mining | ◆ Bundled: N/A | N/A |
| Screenplay | ◆ Bundled: N/A | N/A |
| Solutions | ◆ Bundled: N/A | N/A |
| Studio Web | ◆ Bundled: N/A | N/A |
| Test Manager | ◆ Bundled: N/A | N/A |
Internal third-party component versions
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
This Automation Suite release bundles the following internal components:
| Component | Version |
| Istio | 1.30.3 |
| ArgoCD | 3.5.0 |
| Prometheus | 3.13.2 |
| Grafana | 13.1.3 |
| Fluentd and Fluent-bit | logging-operator: 6.7.0 fluent/fluent-bit: 5.0.9 |
| Gatekeeper | 3.22.2 |
| Cert-Manager | 1.20.3 |
| Velero | 12.0.3 |
