Automation Suite release notes
  • Automation Suite on Linux Release Notes
    • 2.2510.0
      • 2.2510.0+patch2
    • 2.2510.1
    • 2.2510.3
  • Automation Suite on EKS/AKS Release Notes
    • 2.2510.3
  • Automation Suite on OpenShift release notes
2.2510.4
2.2510.4 release notes for Automation Suite on EKS/AKS.
Release date: September 10, 2026
Bug fixes​
  • We fixed an issue that caused the prune-telemetry CronJob to fail on deployments that authenticate to SQL Server using Azure AD (Entra ID) Managed Identity, Default Azure credential, or Workload Identity authentication. The issue occurred due to a missing dependency in the uipathcore container image.
  • An issue caused IdP-initiated SAML sign-in to fail with an "Invalid return URL" error when a Start URL was configured on the identity provider (for example, Google Workspace). We fixed the issue.
  • We fixed an issue where Context Grounding ingestion failed in offline (air-gapped) environments. Previously, ingestion failed for every file type, and the reported error incorrectly indicated a problem with the file contents.
Known issues​
Maestro instance management page rendering issue​
If Insights is enabled on the customer cluster, the Maestro instance management page does not render all information correctly unless the global.insightsRtmEnabled global feature flag is also enabled.
To enable the flag, in ArgoCD, open the Maestro application, select Details, then the PARAMETERS tab, and search for the global.insightsRtmEnabled key. Set its overridden value to true, exit the tab, and wait for ArgoCD to sync. If ArgoCD does not sync automatically, select Sync in the Maestro application.
Kerberos authentication limitations​
Kerberos-based authentication is not supported for the following products and services:
  • Agent Hub
  • Agents
  • AI Trust Layer (LLM Gateway, LLM Observability, Context Grounding)
  • Autopilot for Everyone
  • Autopilot (A4D)
  • Integration Service
  • Maestro
  • Semantic Proxy
  • Solutions
  • Studio Web
  • TaaS
We are working on bringing Kerberos support to upcoming Automation Suite releases.
Meanwhile, you can use alternative authentication mechanisms such as basic authentication or workload identity-based authentication.
FIPS 140-2 support limitations​
Insights is not supported on Automation Suite deployments that run on FIPS 140-2-enabled machines. To remain compliant with FIPS 140-2 requirements, you must disable Insights. If you need to use Insights, you can deploy it on a dedicated non-FIPS node.
MessageBus schema migration fails on databases seeded from Automation Suite 2022.10.x or earlier​
When upgrading to Automation Suite 2.2510.4, the MessageBus schema migration fails if the database was originally created on Automation Suite 2022.10.x or earlier, regardless of how many versions it has been upgraded through since. Databases originally created on Automation Suite 2023.x or later are not affected.
To check whether your database is affected, run the following query:
SELECT * FROM [msgbus].[__EFMigrationsHistory] WHERE MigrationId NOT LIKE '2[0-9][0-9][0-9]%'
If the query returns any rows, delete them before upgrading:
DELETE FROM [msgbus].[__EFMigrationsHistory] WHERE MigrationId NOT LIKE '2[0-9][0-9][0-9]%'
Velero backup components remain after upgrading on AKS from Automation Suite 2024.10.x​
Starting with Automation Suite 2.2510.0, AKS and EKS use the cloud provider's native backup instead, and Velero is no longer a managed component on these distributions. As a result, upgrading Automation Suite on AKS from version 2024.10.x does not remove Velero: its components and the pre-existing backup schedule remain in the cluster and continue to trigger, failing due to storage access errors. uipathctl snapshot commands return an error stating that snapshot commands are not supported for the AKS distribution.
To address the issue, you must manually remove the leftover Velero components. For details, refer to the Troubleshooting section: Velero backup components remain after upgrading on AKS from 2024.10.x.
Deprecation timeline​
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details​
Product versions​
The following table outlines the release status, version, and release notes for all UiPath products deployed under Automation Suite 2.2510.4.
Legend:
✅ New: This Automation Suite version includes a new product version. New release notes are available.
◆ Bundled: This flavor includes a previously released product version. No new release notes are available.
ProductVersionRelease notes
Action Center✅ New: 2.2510.4Action Center release notes
Agents✅ New: 2.2510.4Agents release notes
AI Center✅ New: 2.2510.4AI Center release notes
AI Computer Vision✅ New: 2.2510.4AI Computer Vision release notes
Apps✅ New: 2.2510.4Apps release notes
Automation Hub✅ New: 2.2510.4Automation Hub release notes
Automation Ops✅ New: 2.2510.4Automation Ops release notes
Autopilot for Everyone◆ Bundled: 2025.9.7N/A
Data Service✅ New: 2.2510.4Data Service release notes
Document Understanding✅ New: 2.2510.4Document Understanding AI Center-based projects release notes
Document Understanding modern projects release notes
Healing Agent✅ New: 2.2510.4Healing Agent release notes
Insights✅ New: 2.2510.4Insights release notes
Integration Service✅ New: 2.2510.4Integration Service release notes
Maestro✅ New: 2.2510.4Maestro release notes
Orchestrator✅ New: 2.2510.5Orchestrator release notes
Process Mining✅ New: 2.2510.4Process Mining release notes
Screenplay✅ New: 2.2510.4Screenplay release notes
Solutions✅ New: 2.2510.4Solutions release notes
Studio Web✅ New: 2.2510.4Studio Web release notes
Test Manager✅ New: 2.2510.4Test Manager release notes
Internal third-party component versions​
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
This Automation Suite release bundles the following internal components:
ComponentVersion
Istio1.30.3
ArgoCD3.5.0
Prometheus3.13.2
Grafana13.1.3
Fluentd and Fluent-bitlogging-operator: 6.7.0
fluent/fluent-bit: 5.0.9
Gatekeeper3.22.2
Cert-Manager1.20.3
Velero12.0.3
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
