  • Automation Suite on Linux Release Notes
    • 2.2510.0
      • 2.2510.0+patch2
    • 2.2510.1
  • Automation Suite on EKS/AKS Release Notes
      • 2.2510.2+patch1
      • 2.2510.2+patch2
  • Automation Suite on OpenShift release notes
Automation Suite release notes
2.2510.2+patch2
Release date: June 2, 2026
About this patch
This release applies a patch to Automation Suite 2.2510.2. The patch addresses some issues in Automation Hub, Document Understanding, and Maestro. For more details, refer to the individual product release notes referenced in the Product versions section.
This patch also includes the following fixes:
  • We have fixed an issue related to Semantic Proxy where installation fails in lite mode. The issue occurred due to the semantic proxy container using incorrect CPU/memory resources.
  • We have fixed an issue related to Autopilot (A4D) where installation fails in offline environments. The issue occurred due to Autopilot attempting to access a public API that is not permitted in offline setups.
Important:
These fixes will also be included in all future releases starting with Automation Suite 2.2510.3.
How to apply the patch
To apply this patch, follow the instructions in Applying a patch.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
The following table outlines the release status, version, and release notes for all UiPath products deployed under Automation Suite 2.2510.2+patch2.
Legend
✅ - This Automation Suite version bundles a new version of the product. New release notes are available.
❌ - This Automation Suite version bundles a previously released version of the product. No new release notes are available.
ProductProduct versionRelease statusRelease notes
Action CenterN/AN/A
AgentsN/AN/A
AI CenterN/AN/A
AI Computer VisionN/AN/A
AppsN/AN/A
Automation Hub2.2510.2-patch2Automation Hub release notes
Automation OpsN/AN/A
Autopilot for EveryoneN/AN/A
Data ServiceN/AN/A
Document Understanding2.2510.2-patch2Document Understanding modern projects release notes
Healing AgentN/AN/A
InsightsN/AN/A
Integration ServiceN/AN/A
Maestro2.2510.2-patch2Maestro release notes
ScreenplayN/AN/A
OrchestratorN/AN/A
SolutionsN/AN/A
Process MiningN/AN/A
Studio WebN/AN/A
Test ManagerN/AN/A
Internal third-party component versions
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
This Automation Suite release bundles the following internal components:
ComponentVersion
Istio1.28.3
ArgoCD3.2.6
Prometheus3.9.1
Grafana12.3.1
Fluentd and Fluent-bitlogging-operator: 6.4.0
fluent/fluent-bit: 4.2.3
Gatekeeper3.21.0
Cert-Manager1.19.3
Velero10.1.3
  • About this patch
  • How to apply the patch
  • Deprecation timeline
  • Bundling details
  • Product versions
  • Internal third-party component versions
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
