Automation Suite release notes
  • Automation Suite on Linux Release Notes
    • 2.2510.0
      • 2.2510.0+patch2
    • 2.2510.1
    • 2.2510.3
  • Automation Suite on EKS/AKS Release Notes
    • 2.2510.3
  • Automation Suite on OpenShift release notes
2.2510.1
2.2510.1 release notes for Automation Suite on EKS/AKS.
Release date: December 19, 2025
Support for disabling priority class creation​
You can now disable priority class creation during deployment. This capability is intended for shared cluster environments where priority classes are not required. To enable it, you must edit the input.json configuration file.
For details, refer to Creating a priority class.
Bug fixes​
  • Erratum - added February 9, 2026: We fixed an issue where some Document Understanding microservices failed to start, particularly in IPv4-only environments.
  • We have fixed an issue that caused the prerequisite checks to fail when Process Mining was enabled. The issue occurred due to the checks incorrectly treating cert-manager as a required component, even though it is no longer needed for Process Mining.
  • The Context Grounding service is now available in EKS environments with IPv6 enabled. This fix restores full functionality to Autopilot for Everyone and the GenAI activities that use Context Grounding.
  • This release includes the fixes delivered in Automation Suite 2.2510.0+patch1.
Known issues​
Document Understanding CPU inference setting lost when upgrading to 2.2510.2 or later​
Erratum - added September 10, 2026: If you enabled CPU inference for Document Understanding modern projects (enable_cpu_inference), the setting is not carried over when you upgrade to 2.2510.2 or later. This issue occurs due to a change in the expected location of the enable_cpu_inference parameter in input.json, starting with Automation Suite 2.2510.2.
Before upgrading to Automation Suite 2.2510.2 or later, move the enable_cpu_inference parameter from the documentunderstanding root to the modernProjects section:
// Before
"documentunderstanding": {
    "enable_cpu_inference": false,
    "modernProjects": {
      "enabled": true
// Before
    "modernProjects": {
      "enabled": true
// After (2.2510.2 or later)
    "modernProjects": {
      "enabled": true,
    "modernProjects": {
      "enabled": true,
Studio Desktop cannot load Integration Service connectors and activities​
Erratum - added July 23, 2026: In Studio Desktop, the Activities panel does not list Integration Service connectors and activities. The issue is caused by a routing misconfiguration in the intsvcs-periodic VirtualService.
Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled​
Erratum - added July 23, 2026: An issue causes the prerequisite checks command to incorrectly fail when Document Understanding modern projects is enabled and AI Center is disabled.
To address the issue, refer to Troubleshooting.
This issue is fixed in Automation Suite 2.2510.3.
Custom database names not supported for Solutions​
Erratum - added April 15, 2026: An issue prevents you from using a custom database name for Solutions. If you specify a custom database name, the prerequisite checks fail.
To address this issue, you must use AutomationSuite_AutomationSolutions as the Solutions database name.
This issue is fixed in Automation Suite on EKS/AKS 2.2510.2.
Fluentd does not export logs in IPv6 environments​
Erratum - added April 15, 2026: In IPv6 environments, Fluentbit fails to forward logs to Fluentd because the Fluentd forward input plugin binds to an IPv4 address by default.
To address this issue, you must patch the logging ArgoCD Application and set logging-operator.logging.fluentd.forwardInputConfig.bind to ::. For details, refer to the Troubleshooting section.
AI Center and Document Understanding pods fail to start with TLS certificate verification enabled​
Erratum - added April 15, 2026: When database TLS certificate verification is enabled, some AI Center and Document Understanding pods may get stuck in Init:CrashLoopBackOff. The await-migration-completion init container fails to connect to the database, with TLS/SSL handshake errors in the logs.
Object Store prerequisite validation fails when using Azure Managed Identity​
Erratum - added April 15, 2026: When configuring Azure Blob Storage with a User Assigned Managed Identity, the Object Store prerequisite check incorrectly requires the Storage Account Contributor role. The check fails if the Managed Identity is assigned only the Storage Blob Data Contributor role.
To address the issue, assign the Storage Account Contributor role to the Managed Identity to allow the prerequisite validation to pass.
We fixed the issue in Automation Suite 2.2510.2.
Alertmanager sync failure in ArgoCD​
Erratum - added March 18, 2026: Alertmanager may fail to sync in ArgoCD due to an invalid character in the alertmanager image tag.
To address this issue, update the Helm values under ArgoCD Parameters as follows:
kube-prometheus-stack:
  alertmanager:
    alertmanagerSpec:
      version: v0.29.0
  alertmanager:
    alertmanagerSpec:
      version: v0.29.0
Custom platform database name not supported when installing Process Mining​
Erratum - added March 26, 2026: When Process Mining is enabled, using a custom platform database name causes the OMS backfill job to fail.
As a workaround, use AutomationSuite_Platform as the platform database name when installing Process Mining.
This issue will be fixed in Automation Suite 2.2510.2.
FIPS 140-2 support limitations​
Erratum - added January 22, 2026: Insights and Integration Service are not supported on Automation Suite deployments that run on FIPS 140-2-enabled machines. To remain compliant with FIPS 140-2 requirements, you must disable these services.
For details, refer to Security and compliance.
Kerberos authentication limitations​
Kerberos-based authentication is currently not supported for the following products:
  • Integration Service
  • Autopilot for Everyone
  • AI Trust Layer (LLM Gateway, LLM Observability, Context Grounding)
We are working on bringing Kerberos support to upcoming Automation Suite releases.
Meanwhile, you can use alternative authentication mechanisms such as basic authentication or workload identity-based authentication.
Context Grounding ingestion fails in offline environments​
Erratum - added September 10, 2026: In offline (air-gapped) deployments, Context Grounding document ingestion fails for every file type. The reported error incorrectly indicates a problem with the file contents.
Velero backup components remain after upgrading on AKS from Automation Suite 2024.10.x​
Erratum - added September 10, 2026: Starting with Automation Suite 2.2510.0, AKS and EKS use the cloud provider's native backup instead, and Velero is no longer a managed component on these distributions. As a result, upgrading Automation Suite on AKS from version 2024.10.x does not remove Velero: its components and the pre-existing backup schedule remain in the cluster and continue to trigger, failing due to storage access errors. uipathctl snapshot commands return an error stating that snapshot commands are not supported for the AKS distribution.
To address the issue, you must manually remove the leftover Velero components. For details, refer to the Troubleshooting section: Velero backup components remain after upgrading on AKS from 2024.10.x.
Deprecation timeline​
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details​
Product versions​
The following table outlines the release status, version, and release notes for all UiPath products deployed under Automation Suite 2.2510.1.
Legend:
✅ New: This Automation Suite version includes a new product version. New release notes are available.
◆ Bundled: This flavor includes a previously released product version. No new release notes are available.
ProductVersionRelease notes
Action Center✅ New: 2.2510.1Action Center release notes
AI Center✅ New: 2.2510.1AI Center release notes
AI Computer Vision✅ New: 2.2510.1AI Computer Vision reelase notes
Apps✅ New: 2.2510.1Apps release notes
Automation Hub✅ New: 2.2510.1Automation Hub release notes
Automation Ops✅ New: 2.2510.1Automation Ops release notes
Autopilot for Everyone✅ New: 2025.9.4Autopilot for Everyone release notes
Data Service✅ New: 2.2510.1Data Service release notes
Document Understanding✅ New: 2.2510.1Document Understanding AI Center-based projects release notes
Document Understanding modern projects release notes
Insights✅ New: 2.2510.1Insights release notes
Integration Service✅ New: 2.2510.1Integration Service release notes
Solutions✅ New: 2.2510.1Solutions release notes
Orchestrator✅ New: 2.2510.1Orchestrator release notes
Process Mining✅ New: 2.2510.1Process Mining release notes
Studio Web✅ New: 2.2510.1Studio Web release notes
Test Manager✅ New: 2.2510.1Test Manager release notes
Internal third-party component versions​
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
This Automation Suite release bundles the following internal components:
ComponentVersion
Istio1.28.0
ArgoCD3.2.0
Prometheus3.7.3
Grafana12.2.1
Fluentd and Fluent-bitlogging-operator: 6.0.3
fluent/fluent-bit: 4.0.3
Gatekeeper3.20.1
Cert-Manager1.19.1
Velero10.1.3
Connect
Stay updated
