Automation Suite release notes
  • Automation Suite on Linux Release Notes
    • 2.2510.0
      • 2.2510.0+patch2
    • 2.2510.1
    • 2.2510.3
  • Automation Suite on EKS/AKS Release Notes
  • Automation Suite on OpenShift release notes
2.2510.4
2.2510.4 release notes for Automation Suite on Linux.
Release date: September 10, 2026
Support for new RHEL versions​
We have expanded our OS support to include RHEL versions 9.8 and 10.2. For details on the supported RHEL versions, refer to RHEL compatibility matrix.
Support for the read-only ArgoCD account​
You can now enable the built-in read-only ArgoCD account, argocdro, by setting the fabric.argocd_admin_password parameter in cluster_config.json. For details, refer to Enabling the read-only ArgoCD account.
Bug fixes​
  • In Active/Active deployments, Kerberos KDC discovery could fail because the Kubernetes DNS Service exposed DNS resolution over UDP/53 only. Large Kerberos SRV lookup responses, such as _kerberos._tcp, that required a TCP/53 retry failed, causing Integrated Authentication and LDAP errors. We fixed the issue by enabling TCP/53 on the Kubernetes DNS Service.
  • We fixed an issue that caused the prune-telemetry CronJob to fail on deployments that authenticate to SQL Server using Azure AD (Entra ID) Managed Identity, Default Azure credential, or Workload Identity authentication. The issue occurred due to a missing dependency in the uipathcore container image.
  • We fixed an issue where, in HA environments, the Horizontal Pod Autoscaler and the ArgoCD application controller continuously fought over a workload's replica count, causing it to repeatedly scale up and down.
Known issues​
Cluster data appears lost after a reboot due to incorrect Rancher and etcd disk mount order​
If /var/lib/rancher is mounted on top of the dedicated etcd disk at /var/lib/rancher/rke2/server/db, the etcd data becomes hidden underneath the /var/lib/rancher mount. A reboot that re-triggers this mount order makes the cluster appear to lose all persistent volumes, persistent volume claims, and applications, even though the underlying data is still on disk.
To detect the issue, the uipathctl rke2 prereq run command now checks for this condition. To detect and fix the issue, refer to Cluster data appears lost after a reboot due to incorrect Rancher and etcd disk mount order.
Kerberos authentication limitations​
Kerberos-based authentication is not supported for Integration Service.
We are working on bringing Kerberos support to upcoming Automation Suite releases.
Meanwhile, you can use alternative authentication mechanisms such as basic authentication or workload identity-based authentication.
FIPS 140-2 support limitations​
Insights does not support FIPS. To remain compliant with FIPS 140-2 requirements, you must disable Insights. If you need to use Insights, you can deploy it on a dedicated non-FIPS node.
MessageBus schema migration fails on databases seeded from Automation Suite 2022.10.x or earlier​
When upgrading to Automation Suite 2.2510.4, the MessageBus schema migration fails if the database was originally created on Automation Suite 2022.10.x or earlier, regardless of how many versions it has been upgraded through since. Databases originally created on Automation Suite 2023.x or later are not affected.
To check whether your database is affected, run the following query:
SELECT * FROM [msgbus].[__EFMigrationsHistory] WHERE MigrationId NOT LIKE '2[0-9][0-9][0-9]%'
If the query returns any rows, delete them before upgrading:
DELETE FROM [msgbus].[__EFMigrationsHistory] WHERE MigrationId NOT LIKE '2[0-9][0-9][0-9]%'
Deprecation timeline​
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details​
Product versions​
The following table outlines the release status, version, and release notes for all UiPath products deployed under Automation Suite 2.2510.4.
Legend:
✅ New: This Automation Suite version includes a new product version. New release notes are available.
◆ Bundled: This flavor includes a previously released product version. No new release notes are available.
ProductVersionRelease notes
Action Center✅ New: 2.2510.4Action Center release notes
AI Center✅ New: 2.2510.4AI Center release notes
AI Computer Vision✅ New: 2.2510.4AI Computer Vision release notes
Apps✅ New: 2.2510.4Apps release notes
Automation Hub✅ New: 2.2510.4Automation Hub release notes
Automation Ops✅ New: 2.2510.4Automation Ops release notes
Data Service✅ New: 2.2510.4Data Service release notes
Document Understanding✅ New: 2.2510.4Document Understanding AI Center-based projects release notes
Document Understanding modern projects release notes
Insights✅ New: 2.2510.4Insights release notes
Integration Service✅ New: 2.2510.4Integration Service release notes
Orchestrator✅ New: 2.2510.5Orchestrator release notes
Process Mining✅ New: 2.2510.4Process Mining release notes
Solutions✅ New: 2.2510.4Solutions release notes
Test Manager✅ New: 2.2510.4Test Manager release notes
Internal third-party component versions​
This Automation Suite release bundles the following internal components:
ComponentVersion
RKE21.36.3+rke2r1 (1.36.0+rke2r1 retained for upgrade paths)
ArgoCDv3.5.0 (chart v10.3.2)
gatekeeperv3.22.2
rook1.19.8
ceph19.2.5
prometheus-pushgatewayv1.11.3 (chart v3.6.1)
cert-managerv1.20.3
kube-logging/logging-operator6.7.0
kube-logging/config-reloader6.7.0
istio1.30.3
velero1.18.2
reloaderv1.4.21 (chart v2.2.16)
Prometheusv3.13.2
Grafana13.1.3
redis-operatorv8.0.18-14
redis-clusterv8.0.18-36.14
oauth2-proxyv7.15.3 (chart v10.7.0)
dexv2.45.1 (chart v0.24.1)
external-secretsv2.9.0 (chart v2.9.0)
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
