- Automation Suite on Linux Release Notes
- Automation Suite on EKS/AKS Release Notes
- Automation Suite on OpenShift release notes
2.2510.3
2.2510.3 release notes for Automation Suite on Linux.
Release date: July 23, 2026
Product sizing improvements
We have optimized the minimum hardware requirements for Automation Suite products such as Integration Service and Document Understanding. To check the hardware requirements for deploying Automation Suite 2.2510.3, refer to the capacity planning calculator.
Improved certificate validation error messages
We have improved the error messages returned during prerequisite certificate validation. Checks now report the exact failure, such as incorrect chain order or certificates not belonging to the chain, instead of a generic message.
uipathctl improvements
- The
uipathctl manifest apply --dry-runcommand no longer requires confirmation. Previously, running this command prompted for confirmation. - You can now use the
--nodeflag withuipathctl prereq runto control which node runs the per-node prerequisite checks. Use--node anyto run the checks on any available node without pinning to a specific node,--node <node-name>to run the checks only on that node, or--node all(default) to run the checks on every node, as before. For details, refer to uipathctl prereq run. - You can now configure CPU and memory requests and limits for workloads created by
uipathctl, such as those used for health checks, prerequisite checks, support bundle generation, migrations, and upgrades. Use theworkload_resourcesparameter ininput.json, or the--probe-cpuand--probe-memoryoptions for commands that support them. For details, refer to Configuring resource requests and limits for uipathctl-created workloads.
Romanian language support
The Automation Suite user interface is now available in Romanian.
Bug fixes
- An issue caused the prerequisite checks command to incorrectly fail when Document Understanding modern projects was enabled and AI Center was disabled. We fixed the issue.
- We have fixed an issue that prevented Fluentd from exporting logs in IPv6 environments. Previously, Fluentbit failed to forward logs to Fluentd due to the Fluentd forward input plugin binding to an IPv4 address by default.
- An issue prevented the
monitoringsection parameters incluster_config.jsonfrom being applied to the monitoring stack. We fixed the issue. - An issue prevented
uipathctlfrom resizing an existing data disk partition (such as the Docker registry, monitoring, or Insights partitions) unless the underlying disk path was explicitly provided using the--volumeflag. This behavior was incorrect, sinceuipathctlis designed to automatically detect the associated disk on subsequent runs without requiring--volume. We fixed the issue. - We have fixed an issue where Studio Desktop failed to load Integration Service connectors and activities due to a routing misconfiguration in the
intsvcs-periodicVirtualService. - This release includes the fixes delivered in Automation Suite 2.2510.2+patch1.
- This release includes the fixes delivered in Automation Suite 2.2510.2+patch2.
Known issues
Horizontal Pod Autoscaler and ArgoCD scaling conflict in HA environments
Erratum - added September 10, 2026: In HA environments, when load increases, the Horizontal Pod Autoscaler (HPA) scales the affected workloads up while the ArgoCD application controller scales them back down. This occurs due to ArgoCD treating the replica count defined in the Helm chart or manifest as the source of truth, causing the workloads to repeatedly scale up and down without stabilizing.
To address the issue, you must patch the argocd-cm ConfigMap in the <argocd> namespace so that ArgoCD ignores replica count differences:
kubectl -n <argocd> patch configmap argocd-cm --type merge -p \
'{"data":{"resource.customizations.ignoreDifferences.argoproj.io_Rollout":"jsonPointers:\n- /spec/replicas\n"}}'
Reapply the command after every ArgoCD chart re-sync or Automation Suite upgrade, since both overwrite the ConfigMap and remove the patch.
We fixed the issue in Automation Suite 2.2510.4.
Pods stuck in Init state due to XFS volume mount failure on RHEL 8.x nodes
Erratum - added September 10, 2026: On RHEL 8.x nodes, TopoLVM formats new persistent volumes with XFS on-disk features (bigtime, inobtcount, nrext64) that the RHEL 8.x kernel and xfsprogs version don't support. Pods that request a new PVC, such as AI Center training pipeline pods, remain stuck in the Init state with a mount failed: wrong fs type, bad option, bad superblock error.
To address the issue, refer to Troubleshooting.
Kerberos KDC discovery fails in Active/Active deployments due to truncated DNS SRV responses
Erratum - added September 10, 2026: In Automation Suite Active/Active deployments on Linux (RKE2), Kerberos KDC discovery can fail during installation or upgrade, resulting in Integrated Authentication and LDAP errors. The issue occurs because the Kubernetes DNS Service exposes DNS resolution over UDP/53 only. When a Kerberos SRV lookup, such as _kerberos._tcp or _kerberos._udp, returns a response too large for UDP, the DNS client retries over TCP/53. Since the Kubernetes DNS Service doesn't expose TCP/53, the retry fails.
To address the issue, enable TCP/53 on the Kubernetes DNS Service:
Edit the
rke2-corednsHelm chart configuration:kubectl -n kube-system edit helmchartconfig rke2-corednskubectl -n kube-system edit helmchartconfig rke2-coredns -
Under
zoneinspec.valuesContent, adduse_tcp: true:servers: - zones: - zone: . use_tcp: true port: 53servers: - zones: - zone: . use_tcp: true port: 53
prune-telemetry CronJob fails after upgrading to Automation Suite 2.2510.3
Erratum - added September 10, 2026: After upgrading to Automation Suite 2.2510.3, the prune-telemetry CronJob in the uipath namespace fails on deployments that authenticate to SQL Server using Azure AD (Entra ID) Managed Identity, Default Azure credential, or Workload Identity authentication, with the following error:
Cannot find an authentication provider for 'ActiveDirectoryManagedIdentity'.
Install the 'Microsoft.Data.SqlClient.Extensions.Azure' NuGet package
to use Active Directory (Entra ID) authentication methods.
The issue occurs due to a missing dependency in the uipathcore container image. All CronJob retries fail with this error.
To address the issue, upgrade to Automation Suite 2.2510.4, or you can temporarily delete the failing CronJob:
kubectl delete cronjob prune-telemetry -n uipath
Kerberos authentication limitations
Kerberos-based authentication is not supported for Integration Service.
We are working on bringing Kerberos support to upcoming Automation Suite releases.
Meanwhile, you can use alternative authentication mechanisms such as basic authentication or workload identity-based authentication.
FIPS 140-2 support limitations
Insights does not support FIPS. To remain compliant with FIPS 140-2 requirements, you must disable Insights. If you need to use Insights, you can deploy it on a dedicated non-FIPS node.
For details, refer to Security and compliance and How to deploy Insights in a FIPS-enabled cluster.
MessageBus schema migration fails on databases seeded from Automation Suite 2022.10.x or earlier
When upgrading to Automation Suite 2.2510.3, the MessageBus schema migration fails if the database was originally created on Automation Suite 2022.10.x or earlier, regardless of how many versions it has been upgraded through since. Databases originally created on Automation Suite 2023.x or later are not affected.
To check whether your database is affected, run the following query:
SELECT * FROM [msgbus].[__EFMigrationsHistory] WHERE MigrationId NOT LIKE '2[0-9][0-9][0-9]%'
If the query returns any rows, delete them before upgrading:
DELETE FROM [msgbus].[__EFMigrationsHistory] WHERE MigrationId NOT LIKE '2[0-9][0-9][0-9]%'
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
The following table outlines the release status, version, and release notes for all UiPath products deployed under Automation Suite 2.2510.3.
Legend:
✅ New: This Automation Suite version includes a new product version. New release notes are available.
◆ Bundled: This flavor includes a previously released product version. No new release notes are available.
| Product | Version | Release notes |
| Action Center | ✅ New: 2.2510.3 | Action Center release notes |
| AI Center | ✅ New: 2.2510.3 | AI Center release notes |
| AI Computer Vision | ✅ New: 2.2510.3 | AI Computer Vision release notes |
| Apps | ✅ New: 2.2510.3 | Apps release notes |
| Automation Hub | ✅ New: 2.2510.3 | Automation Hub release notes |
| Automation Ops | ✅ New: 2.2510.3 | Automation Ops release notes |
| Data Service | ✅ New: 2.2510.3 | Data Service release notes |
| Document Understanding | ✅ New: 2.2510.3 | Document Understanding AI Center-based projects release notes Document Understanding modern projects release notes |
| Insights | ✅ New: 2.2510.3 | Insights release notes |
| Integration Service | ✅ New: 2.2510.3 | Integration Service release notes |
| Orchestrator | ✅ New: 2.2510.4 | Orchestrator release notes |
| Process Mining | ✅ New: 2.2510.3 | Process Mining release notes |
| Solutions | ✅ New: 2.2510.3 | Solutions release notes |
| Test Manager | ✅ New: 2.2510.3 | Test Manager release notes |
Internal third-party component versions
This Automation Suite release bundles the following internal components:
| Component | Version |
| RKE2 | 1.36.0+rke2r1 |
| ArgoCD | v3.3.8 |
| gatekeeper | v3.22.2 |
| rook | 1.18.10 |
| ceph | 19.2.3 |
| prometheus-pushgateway | v3.6.0 |
| cert-manager | v1.20.2 |
| kube-logging/logging-operator | 6.5.1 |
| kube-logging/config-reloader | 6.5.1 |
| istio | 1.29.2 |
| velero | 1.18.0 |
| reloader | v2.2.11 |
| Prometheus | v3.11.3 |
| Grafana | 13.0.1 |
| redis-operator | v8.0.18-14 |
| redis-cluster | v8.0.18-36.14 |
| oauth2-proxy | v7.15.2 |
- Product sizing improvements
- Improved certificate validation error messages
- uipathctl improvements
- Romanian language support
- Bug fixes
- Known issues
- Horizontal Pod Autoscaler and ArgoCD scaling conflict in HA environments
- Pods stuck in Init state due to XFS volume mount failure on RHEL 8.x nodes
- Kerberos KDC discovery fails in Active/Active deployments due to truncated DNS SRV responses
- prune-telemetry CronJob fails after upgrading to Automation Suite 2.2510.3
- Kerberos authentication limitations
- FIPS 140-2 support limitations
- MessageBus schema migration fails on databases seeded from Automation Suite 2022.10.x or earlier
- Deprecation timeline
- Bundling details
- Product versions
- Internal third-party component versions
