  • Automation Suite on Linux Release Notes
    • 2.2510.0
      • 2.2510.0+patch2
    • 2.2510.1
  • Automation Suite on EKS/AKS Release Notes
  • Automation Suite on OpenShift release notes
Automation Suite release notes
Last updated May 14, 2026
2.2510.0+patch2
Release date: March 16, 2026
About this patch
This release applies a patch to Automation Suite 2.2510.0. The patch addresses some issues in Process Mining. For more details, see the individual product release notes referenced in the Product versions section.
Important:
This fix will also be included in all future releases starting with Automation Suite 2.2510.2. We recommend that you wait for Automation Suite 2.2510.2 to get this fix.
How to apply the patch
To apply this patch, follow the instructions in Applying a patch.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
The following table outlines the release status, version, and release notes for all UiPath products deployed under Automation Suite 2.2510.0+patch2.
Legend:
✅ - This Automation Suite version bundles a new version of the product. New release notes are available.
❌ - This Automation Suite version bundles a previously released version of the product. No new release notes are available.
ProductProduct versionRelease statusRelease notes
Action CenterN/AN/A
AI CenterN/AN/A
AI Computer VisionN/AN/A
AppsN/AN/A
Automation HubN/AN/A
Automation OpsN/AN/A
Data ServiceN/AN/A
Document UnderstandingN/AN/A
InsightsN/AN/A
Integration ServiceN/AN/A
SolutionsN/AN/A
OrchestratorN/AN/A
Process Mining2.2510.0-patch2Process Mining release notes
Test ManagerN/AN/A
Internal third-party component versions
This Automation Suite release bundles the following internal components:
ComponentVersion
RKE21.34.1+rke2r1
ArgoCDv3.1.5
gatekeeper3.20.0
rook1.17.6
ceph19.2.3
prometheus-pushgatewayv3.4.1
cert-managerv1.18.2
kube-logging/logging-operator6.0.3
kube-logging/config-reloader6.0.3
istio1.26.3
velero1.16.1
reloaderv2.2.0
Prometheusv3.5.0
Grafana12.0.2
redis-operatorv7.22.2-22
redis-clusterv7.22.2-20.focal
oauth2-proxyv7.11.0
  • About this patch
  • How to apply the patch
  • Deprecation timeline
  • Bundling details
  • Product versions
  • Internal third-party component versions
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
