Automation Suite release notes
  • Automation Suite on Linux Release Notes
    • 2.2510.0
      • 2.2510.0+patch2
    • 2.2510.1
    • 2.2510.3
  • Automation Suite on EKS/AKS Release Notes
  • Automation Suite on OpenShift release notes
2.2510.0
2.2510.0 release notes for Automation Suite on Linux.
Release date: March 25, 2026
Support for new RHEL version​
We have expanded our OS support to include RHEL 9.7. For details on the supported RHEL versions, refer to RHEL compatibility matrix.
Release date: November 11, 2025
What's new​
New versioning format for Automation Suite​
Starting with this release, Automation Suite uses a new versioning format. The format follows the pattern [Major].[YYMM].[Patch], defined as follows:
  • Major increases when a major release is delivered.
  • YYMM represents the year and month of the long-term support (LTS) release.
  • Patch increments with each cumulative update (CU) after the initial LTS release.
The version format of this LTS release is 2.2510.0. This release is the baseline for future cumulative updates.
Introducing Test Cloud​
We are excited to announce that Test Cloud is now available on-premises through Linux deployments. This release brings the full Test Cloud experience to self-managed environments, allowing you to design, execute, and manage automated tests securely and at scale within your organization's infrastructure.
Test Cloud enables you to design, execute, and manage automated testing at scale, while maintaining full control of your data, infrastructure, and compliance requirements.
Key benefits of Test Cloud​
Test Cloud offers the following advantages:
  • Comprehensive automation coverage: Supports varied automation types such as Citrix, Web, Desktop, SAP, Mainframe, API, and Mobile.
  • Test data management: Access to diverse data sources to power data-driven testing.
  • Detailed insights: Advanced analytics and reporting features for complete visibility into test performance.
  • Flexible testing methods: Enables both automated and manual testing, as well as data-driven testing through services such as Data Service and Orchestrator, or generated datasets via Autopilot.
Documentation and guidance​
The documentation for Test Cloud on-premises, delivered through Linux deployments is available in the following installation, admin, user, and API guides:
This means that Automation Suite and Test Cloud share content across the release notes, installation, admin, and API guides.
New products onboarded to Automation Suite​
We are happy to announce the addition of Integration Service and Solutions to our Automation Suite product portfolio. This expansion aligns with our aim to maintain parity with the functionalities offered via Automation Cloud.
If you plan to enable these new products, make sure to check out the cross-product dependencies and that you meet all the prerequisites.
All the details about the installation and configuration of these newly onboarded products are available in the Automation Suite on Linux Installation Guide. For details on how make the most out of the functionality of these products, refer to the individual product guides:
Support for single-node production deployment​
Automation Suite now supports single-node deployment for production environments, in addition to evaluation and demonstration scenarios.
This enhancement enables organizations with limited infrastructure resources or specific deployment requirements to operate Automation Suite in a single-node configuration.
Single-node production deployment is supported only when all required conditions are met. These conditions are essential to maintain stability and reliability in production. For details, refer to Single-node production deployment.
While you can use a single-node deployment in production, a multi-node, HA-ready deployment remains the recommended long-term configuration because it provides high availability, scalability, and improved resilience.
Support for Layer 7 (L7) load balancers​
We have added support for Layer 7 (application layer) load balancers, in addition to the existing support for Layer 4 (network layer) load balancers.
This enhancement gives you greater flexibility in deploying Automation Suite in production, enabling advanced traffic management, monitoring, and security features with L7 load balancers.
Support for IPv6 and dual-stack configuration​
Automation Suite now supports deployments using IPv6 and dual-stack (IPv4 and IPv6) networking.
This enhancement allows Automation Suite services and ingress components to run in environments that use IPv6-only or mixed IPv4/IPv6 networks.
For configuration details, refer to the Network requirements section.
Support for external object storage and local disk backups​
Automation Suite now supports additional backup options, providing more flexibility for backup and restore operations.
You can now configure an external objectstorage or a local disk as the location for storing and restoring backup data:
  • External object storage - Supports S3-compatible and Azure objectstores.
  • Local disk - Supported only for single-node clusters. It allows attaching a disk directly to the backup cluster to store backup data, which can later be detached and attached to the restore server for recovery.
To use these options, you must update the cluster_config.json file to include the configuration details for your selected backup method.
PostgreSQL for Process Mining Airflow database​
Starting from Process Mining on Automation Suite 2.2510, you must use PostgreSQL for the AutomationSuite_Airflow database. PostgreSQL runs with the latest versions of Apache Airflow. Latest versions of Apache Airflow have various functionality, performance, and security fixes that older versions lack.
Important:
Using Microsoft SQL Server for the AutomationSuite_Airflow database is no longer supported.
Refer to SQL Requirements for Process Mining and Database configuration for more information on how to set up and configure the PostgreSQL AutomationSuite_Airflow metadatabase.
Admin​
User and group profiles​
Unified profiles for audit and troubleshooting​
We are happy to announce that we have introduced a unified view where you can check and manage all the necessary information about your user accounts and local groups. We refer to this view as user and group profiles.
User and group profiles are the solution you need to easily audit and troubleshoot your user or group configurations. Unlike before, you can now perform a wide array of operations from one single location: customize group memberships, handle licenses, monitor access, and update user and group info.
Currently, user and group profiles are available for Organization Admins only.
How to use user and group profiles​
To access user and group profiles, navigate to Admin > Accounts & local groups, choose either the User accounts or the Local groups tab, then select the user account or local group you want to manage. A new window opens, allowing you to view or update your user or group configurations.
The following image shows some of the options you have for managing user profiles:
For a comprehensive list of all the operations you can perform using the new user and group profiles, refer to Managing user group and profiles.
Introducing the tenant administrator role​
First cross-service role​
We are excited to announce the Tenant Administrator role in Automation Suite.
This new cross-service role enables you to delegate responsibilities more efficiently by designating users, groups, robot accounts, or external applications to manage all resources within a given tenant.
You can now delegate tasks such as role assignment, licensing management, service provisioning, and more, to a Tenant Administrator without worrying about them having access to any other resources within your organization.
Ideal for RPA CoE Directors and IT Administrators, the Tenant Administrator role allows reassigning some tasks from an Organization Administrator to a tenant-level role.
Benefits of the Tenant Administrator role​
If you are curious about the benefits of the new Tenant Administrator role, here they are:
  • Enhanced operational efficiency: This new role reduces the time required to set up the admin for tenant-level operations;
  • Reduced workload for Organization Administrators: It eases the burden on the Organization Administrators;
  • Improved security: Since fewer users have maximum permissions, there is greater control on access rights.
You will be pleased to learn that the Tenant Administrator role is just the first tenant-level role we plan to introduce. Our goal is to allow you to manage cross-service roles from a central location.
Known limitations​
The Tenant Administrator role is currently affected by the following known limitations, which we are actively working on overcoming:
  • Only the following services support the Tenant Administrator role: Orchestrator (includes Actions, Processes, Integration Service), Data Service, Document Understanding, Task Mining, Test Manager. The rest of the tenant-level services are currently not supported, and users with only the Tenant Administrator role cannot access these services.
  • The Tenant Administrator cannot access organization-level menus from the interface.
  • On the Admin > Tenants > Services screen, the Tenant Administrator can view enabled services, but cannot add or remove services.
  • On the Admin > Tenants > Manage access screen, the Tenant Administrator can view tenants they do not administer. However, if the Tenant Administrator accesses these tenants, they cannot perform any actions.
For more details on the new Tenant Administrator role and how to assign it, refer to Tenant-level roles.
Tenant picker enhancements​
We are pleased to present a new design, and functionality for the platform tenant picker.
The enhancements include a search box for easy navigation when you have multiple tenants, and the region in which each tenant's data resides.
Figure 1. Tenant picker data residency
Centralized access management​
We are excited to introduce the centralized access management initiative. Centralized access management provides you with streamlined access management processes and enhanced customization capabilities. These features allow you to easily manage roles and permissions across your organization, improving efficiency, compliance, and troubleshooting.
Explore the following key areas we updated and discover their new features:
Compliance and auditing​
  • Export role assignments via API, or the UI
    You can now export roles and role assignments for all products and services across the platform via API, or via the user interface (UI) by selecting the Download role assignments button in the Accounts & local groups menu. This feature simplifies audits, compliance, and reporting by providing a centralized view of role assignments across your environment. For more information, refer to Export user role assignments for API instructions, or Exporting role assignments for UI instructions.
  • Check access folder support
    Check access enables Organization Administrators and Tenant Administrators to easily review the roles and permissions assigned to users, groups, accounts, and external applications across both tenant and service level. Folder-level support is also available. You can view which roles are associated with specific folders, providing a more complete and accurate representation of access permissions across the platform. Additionally, all permission details can be exported to a CSV file for further review and reporting. To use the feature, go to Admin > Manage access > Check access, then search for any account to review its roles and permissions. For more information, refer to Checking access.
Centralization​
  • Custom roles
    Custom roles are now available at organization, tenant, and service levels. You can define new roles using a combination of permissions from one or multiple services within a tenant, ensuring tailored access control for their specific role needs. For more information, refer to Custom roles.
  • Tenant Admin role
    This new cross-service role enables greater efficiency in delegating responsibilities, as users, groups, robot accounts, or external applications can manage all resources within a designated tenant. If you are an Organization Administrator, you can now delegate responsibilities such as role assignment, licensing management, and service provisioning to a Tenant Administrator, decreasing concerns over undesired access to other resources within your organization. For more details on the new Tenant Administrator role and how to assign it, refer to Tenant-level roles.
  • Insights dashboard viewer role
    The Insights dashboard viewer role is a new role at organization level that enables you to assign specific and more granular access to Insights dashboards at organization level, without having to grant users with full organization administrator privileges. This role targets access to dashboards, providing you with more control and flexibility in sharing insights across the organization. For more information, refer to Organization-level roles.
  • Tenant types and tagging
    You can now choose the tenant type for your tenant when you create a new one by selecting Production, Staging or Development from the Environment type section in the Create a new tenant UI wizard. This capability makes tenant management more intuitive, freeing you from the hassle of maintaining strict naming conventions for your tenants. Additionally, this feature allows you to tag tenants based on their purpose, and streamlines administrative tasks. For more information, refer to Adding tenants.
Consistency​
  • The Manage access menu
    We have redesigned the Manage access menu to ensure a consistent look across all platform levels: organization, tenant, and service. Regardless of the platform level you work at, you experience the same interface for managing roles and role assignments. This consistent approach reduces friction when navigating between different scopes and enhances overall usability. For more information, refer to Manage access user interface based on scope.
Redesigned left rail for enhanced navigation​
In our continuous efforts to enhance your user experience, we are excited to announce a redesigned left rail in Automation Cloud to ensure you can easily access key parts of the platform.
The new left rail is custom-tailored, displaying only your favorite services and modules, which you can effortlessly personalize. All accessible services that you have access to are still available, but in order to see them, you need to expand the left rail.
To add a service to favorites, hover over it and select the gray Favorites icon next to the service name. To remove a service from favorites, use the orange Favorites icon.
Figure 2. New left-rail with favorites section
For a comprehensive description of the new navigation experience, refer to The left rail.
Enjoy navigating through the revised design!
Licensing​
Unified Pricing, an innovative licensing model​
We are excited to announce Unified Pricing, our enhanced licensing model that brings new licensing plans, user licenses, and an innovative credit-based approach. These features make it a compelling alternative to the existing Flex licensing model.
Key benefits​
Unified Pricing introduces the following new features:
  • Credit-based approach: Under Unified Pricing, all licensing consumption units - such as AI Units, App Units, Robot Units, API Calls, and Agent Units - are consolidated into a single unit, the Platform Unit. This simplification allows for easier understanding and tracking.
  • Enhanced flexibility: With Unified Pricing, you can easily reallocate Platform Units based on your changing project needs. Now that multiple UiPath services consume Platform Units, you are no longer constrained to pre-defined uses for the acquired units. This allows you to shift your focus and resources where your projects need them the most, whenever you require.
Who can benefit​
Currently, you can acquire Unified Pricing licensing plans for Automation Cloud products, Automation Suite products, and desktop products. This new licensing model caters to the needs of both existing and new customers.
If you want to continue with your existing Flex licensing model, you are free to make that choice. However, if you are currently operating under the Flex model and wish to switch to Unified Pricing, remember that this transition will require that you ensure user license management is enabled and you re-assign licenses. For more guidance, reach out to your Sales representative.
Additional resources​
For comprehensive information on the user SKUs available in Unified pricing, refer to UiPath Licensing.
For guidance on how to select the optimal licensing model tailored to your needs, refer to the Overview guide.
For specifics related to the newly introduced Unified Pricing plans, user licenses, and Platform Units on the platform-level, refer to the Automation Suite admin guide.
For information on the consumption logic applicable to each UiPath product, detailed user guides for each product are available.
Improved tenant-level license tracking and assignment​
You can now monitor the quantity of runtimes that are currently in use by a tenant, in addition to the number of licenses that are available for allocation. You can check this new value in the Edit license allocation panel for the selected tenant, by choosing the Licenses card in the Admin section.
This new feature helps you avoid the re-assignment of licenses already in use, by making it easier to count and assign the remaining licenses. For details, refer to License overallocation.
The following image shows the Edit license allocation panel, where you can view the number of both available and in-use licenses.
Introducing quotas per user group​
We are excited to announce a new enhancement to our user licensing management system: quotas per user groups. This feature allows organization administrators to control the number of user licenses a group can acquire. In essence, users belonging to each group can now acquire licenses up to the set quota. This streamlines the allocation and overall management of licenses across multiple business units within your organization.
Key benefits​
With quotas per user groups, you can enjoy the following benefits:
  • Elevated control: As an organization administrator, you can restrict the number of user licenses a group can acquire, which gives you better control of licenses across your organization.
  • Enhanced efficiency: As an administrator, you can control the number of licenses allocated to specific groups of users. This allows for more targeted license management compared to managing licenses via group allocation only. Administrators can use this mechanism, and combined with permissions, they can restrict the access of a group of users to specific tenants and a specific number of licenses.
Usage notes​
When you are adding or editing a license allocation rule for a group, you, as an organization administrator, can now control the quotas per user group. For more information, refer to Managing license allocation rules.
As you navigate the new feature, there are some key points to keep in mind:
  • Minimum quota: The minimum quota value that can be set is 1. If a quota is set to 0, an error message will guide you towards a valid action.
  • Unlimited upper quota: We do not set an upper limit to quota. Setting the quota higher than the available licenses simply means users can acquire up to the maximum available licenses. However, note that this is not a recommended configuration.
  • Lowering quota: If you attempt to set a quota that is lower than the number of licenses already acquired by a group, an error message will appear suggesting the need to adjust existing allocations. For details, refer to Deallocating directly assigned licenses.
This enhancement is designed to simplify the task of managing licenses within your organization.
Identity​
Manage UiPath's signing certificate for SAML authentication requests via API​
If your identity provider (IdP) does not support automatically consuming updates from UiPath's SAML metadata URL, and you require signed authentication requests or responses, you will not be able to reliably update verification certificates in your IdP.
In this case, you can now upload your own verification certificate via API endpoints, and ensure you meet your IT requirements for signed SAML requests or responses. For step-by-step information on uploading a verification certificate, visit Managing UiPath signing certificate for SAML authentication requests.
API support for managing OAuth external applications​
You can now use APIs to automate client secret rotation for external applications. This helps meet security requirements by reducing the risks associated with secrets used on a long term, or with manually rotated secrets.
The new APIs allow you to:
  • List and manage OAuth external client applications.
  • Create, update, and delete secrets for OAuth external applications.
  • Generate secrets using fine-grained scopes.
For more details, visit External client APIs.
Administrators can create consent prompts for users logging into the organization. This feature ensures each user is acquainted and in compliance with your organization's policies before stepping into your UiPath ecosystem.
Support for restricting access to organizations​
We are happy to announce that you can now easily manage the user access to your organizations. The new functionality gives you more control over which devices from your network can access specific organizations in Automation Cloud. You can now prevent unauthorized access to specific organizations, even from company-controlled devices.
This enhancement mitigates the risk of misused resources and unauthorized data access. Experience the extra layer of security that this feature ensures by providing consistent control over your UiPath environment.
For details on how to make the most of this feature, see Restricting access to organizations.
Deprecated API endpoint​
The /identity_/api/User/{userId}/loginAttempts endpoint has been deprecated. Switch to using the /{organization_name}/portal_/api/auditLog endpoint for audit logs.
Improvements​
We have expanded our OS support to include RHEL 9.6. For details on the supported RHEL versions, see Compatibility Matrix.
Istio HSTS enabled by default​
To enhance security, Istio HSTS is now enabled by default.
uipathctl improvements​
  • You can now list all the available options for the included and excluded flags when running the prerequisite checks command. For more details about --list-options, refer to the uipathctl reference guide.
  • For better eficiency, the diagnostic checks are no longer executed during the bundle creation process. Previously, a health check was performed by default during the support bundle creation, requiring the explicit use of the --skip-diagnose flag to bypass it. For more details on how to run the diagnostic checks, refer to the uipathctl reference guide.
Additional custom CA certificate support​
You can include any additional custom CA certificate by providing the additonal_ca_certs key with the external CA certificate path in the cluster_config.json file.
Optional monitoring configuration​
You can now choose to enable or disable built-in monitoring in Automation Suite, giving your organization flexibility to use its own observability stack.
Enhanced telemetry and configuration insights​
We are now including high-level summarized telemetry in Automation Suite support bundle, providing insights into environment configuration, resource utilization, and command execution. We also include guidance on how to view the generated XML file and enabled telemetry sharing with UiPath Support via the Customer Portal.
New alert for Redis license expiration​
We have added a new Prometheus alert for the expiration of internal Redis licenses. This alert has three notification levels, based on the timeframe the license is set to expire: 90, 30, or 7 days.
Removals​
Full migration option no longer available​
The full migration option to move standalone product data to Automation Suite is no longer available. The single tenant migration method, powered by the Automation Cloud™ Migration Tool, is now the only supported way to transfer Orchestrator entities.
For details, refer to the Migration and upgrade section.
Task Mining no longer available in Automation Suite 2.2510​
Unassisted Task Mining is a deprecated feature and will be removed on December 1, 2025. As Task Mining in Automation Suite only consists of Unassisted Task Mining, the implies that Task Mining is no longer available in Automation Suite 2.2510.
If Task Mining was installed in a previous version of Automation Suite, it will no longer be visible after upgrading to version 2.2510.
Important:
Internally, Task Mining depended on the Dapr service, which also has been removed. After successfully upgrading or migrating from a version of Automation Suite that had Task Mining enabled, make sure to delete the Task Mining node, database, and storage, or adjust the nodes for internal use cases by updating taints and tolerations as needed.
Removal of AWS, Azure, and GCP deployment template​
We have removed the following deployment templates:
  • AWS deployment template
  • Azure deployment template
  • GCP deployment template
Previously, these templates were used to provide predefined configurations for installing Automation Suite on the supported public cloud providers.
As an alternative, use Automation Suite on EKS/AKS, or contact UiPath Support for assistance.
Bug fixes​
  • An issue caused the uipathctl cluster pre-upgrade command to fail for offline runs with an in-cluster registry. This issue occured if any of the ArgoCD applications were out of sync before the pre-upgrade. We have fixed the issue.
  • An issue prevented the uipathctl cluster pre-upgrade command from completing successfully in environments configured with a proxy and external object store, due to an error during the Insights volume migration process. We have fixed the issue.
  • An issue caused autogenerated self-signed certificates to be created with a 10-year validity instead of 90 days. This behavior no longer occurs, and certificates are now correctly created with a 90-day validity.
  • An issue caused Kubernetes nodes to crash when the /var/lib/rancher partition filled up. This issue occurred due to eviction thresholds not being applied to the file system that stores container images. The issue no longer occurs, and nodes now correctly detect disk pressure on the image file system and evict workloads before the partition reaches capacity.
  • An issue prevented the required pods from being created when enabling GPU after adding a GPU node. This issue occurred only when using external registries with project names ( such as Harbor). We have fixed the issue.
  • An issue caused the Thanos compactor to stop metrics block compaction in the object store due to a race condition in Prometheus. This led to increased storage usage in the Ceph bucket. We have fixed the issue.
  • We have fixed an issue that blocked the Automation Suite upgrade on a backup-restored cluster.
  • An issue was causing the node-monitor component, which monitors the node for issues such as checking kube-proxy health or if ip_forward is enabled, and cordons the node if issues arise, to not work for specific nodes such as GPU or as-robot. We have fixed the issue.
  • Previously, the configuration of user authentication and SQL authentication for the Automation Suite cluster was interconnected. To use either of them, you had to set both kerberos_auth_config.enabled and kerberos_auth_config.enable_integrated_sql_auth parameters to true. Currently, we allow independent configuration of only user authentication by setting kerberos_auth_config.enabled to true and kerberos_auth_config.enable_integrated_sql_auth to false. Independent SQL authentication is still not supported.
  • We have fixed an issue causing the update FQDN flow to fail due to a security configuration. The behavior no longer occurs.
  • We have fixed an issue causing the custom changes made to the RKE2 configuration file (/etc/rancher/rke2/config.yaml) to be overwritten during upgrades. Now, the custom configurations are preserved.
  • We have fixed an issue causing Automation Suite installations to fail due to Certificate Authority (CA) certificates not being recognized. The issue occurred when the CertificatePolicies section included policy OID values exceeding 4 bytes.
  • We have fixed an issue caused by the update_fqdn parameter not being properly set in the service-cluster-configurations secret. As part of this fix, the update_fqdn flag is now being removed after updating the FQDN. We have also corrected the display message for running the uipathctl rke update-fqdn command.
  • This release brings security updates to address CVE-2025-55315.
Known issues​
Horizontal Pod Autoscaler and ArgoCD scaling conflict in HA environments​
Erratum - added September 10, 2026: In HA environments, when load increases, the Horizontal Pod Autoscaler (HPA) scales the affected workloads up while the ArgoCD application controller scales them back down. This occurs due to ArgoCD treating the replica count defined in the Helm chart or manifest as the source of truth, causing the workloads to repeatedly scale up and down without stabilizing.
To address the issue, you must patch the argocd-cm ConfigMap in the <argocd> namespace so that ArgoCD ignores replica count differences:
kubectl -n <argocd> patch configmap argocd-cm --type merge -p \
  '{"data":{"resource.customizations.ignoreDifferences.argoproj.io_Rollout":"jsonPointers:\n- /spec/replicas\n"}}'
Reapply the command after every ArgoCD chart re-sync or Automation Suite upgrade, since both overwrite the ConfigMap and remove the patch.
We fixed the issue in Automation Suite 2.2510.4.
Document Understanding CPU inference setting lost when upgrading to 2.2510.2 or later​
Erratum - added September 10, 2026: If you enabled CPU inference for Document Understanding modern projects (enable_cpu_inference), the setting is not carried over when you upgrade to 2.2510.2 or later. This issue occurs due to a change in the expected location of the enable_cpu_inference parameter in cluster_config.json, starting with Automation Suite 2.2510.2.
Before upgrading to Automation Suite 2.2510.2 or later, move the enable_cpu_inference parameter from the documentunderstanding root to the modernProjects section:
// Before
"documentunderstanding": {
    "enable_cpu_inference": false,
    "modernProjects": {
      "enabled": true
// Before
    "modernProjects": {
      "enabled": true
// After (2.2510.2 or later)
    "modernProjects": {
      "enabled": true,
    "modernProjects": {
      "enabled": true,
Kerberos KDC discovery fails in Active/Active deployments due to truncated DNS SRV responses​
Erratum - added September 10, 2026: In Automation Suite Active/Active deployments on Linux (RKE2), Kerberos KDC discovery can fail during installation or upgrade, resulting in Integrated Authentication and LDAP errors. The issue occurs because the Kubernetes DNS Service exposes DNS resolution over UDP/53 only. When a Kerberos SRV lookup, such as _kerberos._tcp or _kerberos._udp, returns a response too large for UDP, the DNS client retries over TCP/53. Since the Kubernetes DNS Service doesn't expose TCP/53, the retry fails.
To address the issue, enable TCP/53 on the Kubernetes DNS Service:
  1. Edit the rke2-coredns Helm chart configuration:
    kubectl -n kube-system edit helmchartconfig rke2-coredns
  2. Under zone in spec.valuesContent, add use_tcp: true:
    servers:
    - zones:
      - zone: .
        use_tcp: true
      port: 53
    servers:
    - zones:
      - zone: .
        use_tcp: true
      port: 53
Studio Desktop cannot load Integration Service connectors and activities​
Erratum - added July 23, 2026: In Studio Desktop, the Activities panel does not list Integration Service connectors and activities. The issue is caused by a routing misconfiguration in the intsvcs-periodic VirtualService.
We fixed the issue in Automation Suite 2.2510.3.
Resizing a data disk partition requires the disk path even on subsequent runs​
Erratum - added July 23, 2026: An issue prevents uipathctl from resizing an existing data disk partition (such as the Docker registry, monitoring, or Insights partitions) unless the underlying disk path is explicitly provided using the --volume flag. This behavior is incorrect, since uipathctl is designed to automatically detect the associated disk on subsequent runs without requiring --volume.
This issue is fixed in Automation Suite 2.2510.3.
Support bundle daemon sets are not cleaned up after collection​
Erratum - added July 23, 2026: An issue prevents the support bundle daemon sets from being cleaned up on each node after a support bundle collection request finishes.
Before triggering a new support bundle request, delete the existing support bundle daemon set:
kubectl -n kube-system delete daemonset/support-bundle-daemon --ignore-not-found
This issue is fixed in Automation Suite 2.2510.2.
Monitoring configuration updates do not take effect​
Erratum - added July 23, 2026: An issue prevents the monitoring section parameters in cluster_config.json from being applied to the monitoring stack.
Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled​
Erratum - added July 23, 2026: An issue causes the prerequisite checks command to incorrectly fail when Document Understanding modern projects is enabled and AI Center is disabled.
To address the issue, refer to Troubleshooting.
Custom database names not supported for Solutions​
Erratum - added April 15, 2026: An issue prevents you from using a custom database name for Solutions. If you specify a custom database name, the prerequisite checks fail.
To address this issue, you must use AutomationSuite_AutomationSolutions as the Solutions database name.
Fluentd does not export logs in IPv6 environments​
Erratum - added April 15, 2026: In IPv6 environments, Fluentbit fails to forward logs to Fluentd because the Fluentd forward input plugin binds to an IPv4 address by default.
To address this issue, you must patch the logging ArgoCD Application and set logging-operator.logging.fluentd.forwardInputConfig.bind to ::. For details, refer to the Troubleshooting section.
FQDN update fails in IPv6 and dual-stack environments​
Erratum - added April 15, 2026: In IPv6 and dual-stack environments, FQDN updates fail at both the infrastructure level and the service level.
We fixed the issue in Automation Suite 2.2510.2.
AI Center and Document Understanding pods fail to start with TLS certificate verification enabled​
Erratum - added April 15, 2026: When database TLS certificate verification is enabled, some AI Center and Document Understanding pods may get stuck in Init:CrashLoopBackOff. The await-migration-completion init container fails to connect to the database, with TLS/SSL handshake errors in the logs.
Prerequisite check incorrectly validates monitoring and logging components​
Erratum - added April 15, 2026: The prerequisite check incorrectly validates monitoring and logging components. Since these components are installed after the prerequisite phase, this validation is not necessary.
Insights real-time monitoring not working on the secondary cluster in Active/Active deployments​
Erratum - added April 15, 2026: In Active/Active deployments with Insights real-time monitoring enabled, Orchestrator and platform services on the secondary cluster do not push real-time monitoring data due to configuration issues with call redirection from the secondary cluster to the primary cluster.
Custom platform database name not supported when installing Process Mining​
Erratum - added March 26, 2026: When Process Mining is enabled, using a custom platform database name causes the OMS backfill job to fail.
As a workaround, use AutomationSuite_Platform as the platform database name when installing Process Mining.
This issue will be fixed in Automation Suite 2.2510.2.
Document Understanding services not starting​
Erratum - added February 9, 2026: We discovered that some Document Understanding microservices may fail to start, particularly in IPv4-only environments.
We fixed the issue in Automation Suite 2.2510.1.
FIPS 140-2 support limitations​
Erratum - added January 22, 2026: Insights and Integration Service are not supported on Automation Suite deployments that run on FIPS 140-2-enabled machines. To remain compliant with FIPS 140-2 requirements, you must disable these services.
For details, refer to Security and compliance.
Prerequisite checks fail when Process Mining is enabled​
Erratum - added December 19, 2025: An issue causes the prerequisite checks to fail when Process Mining is enabled. The issue occurs due to the checks incorrectly identifying cert-manager as a required component, even though it is no longer needed for Process Mining.
The failure message is a false positive and can be safely ignored.
GPU enablement fails in offline clusters with in-cluster registry​
Erratum - added December 19, 2025: An issue prevents theuipathctl rke2 gpu --enable command from deploying the nvidia-gpu-plugin DaemonSet pods on GPU nodes. The issue occurs in offline clusters that use an in-cluster registry.
To address the issue, you must update the GPU plugin manifest before running the uipathctl rke2 gpu --enable command. Replace <Installer_Directory> with the path to your installer directory (such as /opt/UiPathAutomationSuite), and run the following command:
sed -i "s/REGISTRY_PLACEHOLDER/localhost:30071/g" "<Installer_Directory>/Infra_Installer/gpu_plugin/nvidia-device-plugin.yaml"
Upgrade fails due to http-echo image seeding error​
Erratum - added December 19, 2025: An issue prevents the Automation Suite upgrade from completing due to a failure in seeding the hashicorp/http-echo:1.0 image.
To address the issue, you must manually remove the http-echo image reference from the .images section in versions/helm-charts.json and versions/1.34.1/helm-charts.json, and then perform the registry-specific operations again.
Hostname case sensitivity causes upgrade failure​
Erratum - added December 19, 2025: An issue prevents upgrade operations from completing when a node hostname is uppercase. The issue is due to Kubernetes normalizing the kubernetes.io/hostname label to lowercase, which can cause a mismatch during upgrade-server deployment creation.
To address the issue, refer to the Troubleshooting section.
Kerberos authentication limitations​
Erratum - added December 19, 2025: Kerberos-based authentication is currently not supported for Integration Service.
We are working on bringing Kerberos support to upcoming Automation Suite releases.
Meanwhile, you can use alternative authentication mechanisms such as basic authentication or workload identity-based authentication.
SQL check failure with workload identity enabled​
An issue may cause the prereq check and health diagnose commands to report a failure for the SQL check. This issue can occur in environments where workload identity is enabled for Apps, Automation Hub, and Integration Service.
Deprecation timeline​
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details​
Product versions​
The following table outlines the release status, version, and release notes for all UiPath products deployed under Automation Suite 2.2510.0.
Legend:
✅ New: This Automation Suite version includes a new product version. New release notes are available.
◆ Bundled: This flavor includes a previously released product version. No new release notes are available.
ProductVersionRelease notes
Action Center✅ New: 2.2510.0Action Center release notes
AI Center✅ New: 2.2510.0AI Center release notes
AI Computer Vision✅ New: 2.2510.0AI Computer Vision release notes
Apps✅ New: 2.2510.0Apps release notes
Automation Hub✅ New: 2.2510.0Automation Hub release notes
Automation Ops✅ New: 2.2510.0Automation Ops release notes
Data Service✅ New: 2.2510.0Data Service release notes
Document Understanding✅ New: 2.2510.0Document Understanding AI Center-based projects release notes
Document Understanding modern projects release notes
Insights✅ New: 2.2510.0Insights release notes
Integration Service✅ New: 2.2510.0Integration Service release notes
Solutions✅ New: 2.2510.0Solutions release notes
Orchestrator✅ New: 2.2510.0Orchestrator release notes
Process Mining✅ New: 2.2510.0Process Mining release notes
Test Manager✅ New: 2.2510.0Test Manager release notes
Internal third-party component versions​
This Automation Suite release bundles the following internal components:
ComponentVersion
RKE21.34.1+rke2r1
ArgoCDv3.1.5
gatekeeper3.20.0
rook1.17.6
ceph19.2.3
prometheus-pushgatewayv3.4.1
cert-managerv1.18.2
kube-logging/logging-operator6.0.3
kube-logging/config-reloader6.0.3
istio1.26.3
velero1.16.1
reloaderv2.2.0
Prometheusv3.5.0
Grafana12.0.2
redis-operatorv7.22.2-22
redis-clusterv7.22.2-20.focal
oauth2-proxyv7.11.0
Connect
Stay updated
