# uipathctl rke2 node remove
> Gracefully remove Kubernetes nodes from cluster in Automation Suite on Linux.
## Description
Gracefully remove the k8s nodes.
uipathctl rke2 node remove [flags]
## Options
  -h, --help                     help for remove
      --ignore-lock              [CAUTION] Ignore single instance lock check. Use this only when previous script run failed to remove lock
      --ignore-missing-tainted   Ignore if a replacement tainted node is not available in the cluster
      --ignore-missing-zone      Ignore if a replacement node is not available in the same zone as provided nodes
  -n, --name string              [Required] : Comma separated list of node names to remove from the cluster.
## Options inherited from parent commands
