# uipathctl prereq run
> Run prerequisite checks to validate installation success in Automation Suite.
## Description
Runs the prerequisite checks to validate that the installation would succeed.
uipathctl prereq run PATH [flags]
## Examples
# Runs all the prerequisite checks
uipathctl prereq run input.json/cluster_config.json --versions versions.json
# Runs the prerequisite checks on any available node without pinning to a specific node
uipathctl prereq run input.json/cluster_config.json --node any --versions versions.json
# Runs the prerequisite checks only on a specific node
uipathctl prereq run input.json/cluster_config.json --node <node-name> --versions versions.json
## Options
  -h, --help              help for run
      --node string        node on which to run the per-node prerequisite checks. one of [all, any, <node-name>] (default all)
  -o, --output output     output format. one of [json,yaml,text] (default text)
  -v, --verbose           verbose output
      --versions string   path to versions file
      --list-options      list all available options for the included and excluded flags
## Options inherited from parent commands
      --excluded strings    components to be excluded from execution, defaults to none
      --included strings    components to be included in the execution, defaults to all
      --upgrade             include upgrade-related checks
