# uipathctl config enable-basic-auth
> Enable basic authentication sign-in for organization in Automation Suite.
## Description
Enable basic auth enables basic sign-in for the provided organization.
The command defaults to the current context in the `kubeconfig` file. If the `--kubeconfig` flag is set, it uses the `kubeconfig` file specified by the flag.
uipathctl config enable-basic-auth [flags]
## Examples
 # Enable basic auth for the provided organization in cluster
 uipathctl config enable-basic-auth --orgname organization
 # Enable basic auth for the provided organization in the cluster identified by the current context in the kubeconfig file
 uipathctl config enable-basic-auth --orgname organization --kubeconfig cluster.kubeconfig
## Options
  -h, --help               help for enable-basic-auth
      --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")
      --orgname string     organization name
## Options inherited from parent commands
