# Deployment architecture
> Supported deployment modes, architecture concepts, and node topology options for Automation Suite.
## Terminology
For details on the core concepts used in an Automation Suite deployment, refer to [Glossary](https://docs.uipath.com/automation-suite/automation-suite/2.2510/installation-guide/glossary#glossary).
## Deployment modes and use cases
Automation Suite supports the following deployment modes:
| Deployment mode | Description |
| **Single-node** | Supported for evaluation and demo scenarios. For details, refer to [Single-node evaluation deployment](#single-node-evaluation-deployment).Can also be used in production under specific conditions. For details, refer to [Single-node production deployment](#single-node-production-deployment). |
| **Multi-node** | Supported for production use. The following modes are available:- **Lite mode**: Lightweight deployment with selective HA configuration. For details, refer to [Lite mode deployment](#lite-mode-deployment).- **HA mode**: Fully enabled HA. For details, refer to [Multi-node HA-ready production deployment](#multi-node-ha-ready-production-deployment). |
:::note
Single-node deployments can be converted to high availability (HA) setups by adding the additional hardware required for multi-node deployments. For details, refer to the [Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment](https://docs.uipath.com/automation-suite/automation-suite/2.2510/installation-guide/scaling-a-single-node-evaluation-deployment-to-a-multi-node-ha-deployment#scaling-a-single-node-(evaluation)-deployment-to-a-multi-node-(ha)-deployment) page.
Automation Suite uses a cloud native architecture based on Kubernetes. It provides all the benefits in scale, automatic resource management, and reliability that come with Kubernetes.
To offer these benefits, the Kubernetes design is based on the following fundamental aspects:
* Running on an uneven number of multiple machines (3, 5, 7, etc.);
* Using the quorum principle to handle independent node failures and data corruption. For a cluster of N machines, as long as there is still a number of N/2 + 1 machines that have quorum, the cluster is functional and can recover gracefully with no observed failures.
## Deployment architecture
This page offers insight into the Automation Suite architecture and describes the components bundled into the installer.
### Node types
The following diagram shows the node types available in an Automation Suite deployment.
  ![Automation Suite node types: server nodes, agent nodes, and specialized agent nodes](https://dev-assets.cms.uipath.com/assets/images/automation-suite/automation-suite-node-types-598635-d77cce16.webp)
A **server** node hosts cluster management services (control plane) that perform important cluster operations such as workload orchestration, cluster state management, load balance incoming requests, etc. Kubernetes may also run a few of the UiPath® products and shared components based on underlying resource availability.
An **agent** node is responsible for running the UiPath® products and shared components only.
A **specialized agent** node runs special workloads like Document Understanding pipelines that require GPU capability, or Automation Suite Robots. However, the core Document Understanding, or Automation Suite Robots services still run on the server or agent nodes. Specialized agent nodes do not host any of the UiPath® product or shared components.
:::important
Automation Suite cannot guarantee which UiPath® product runs on each node. This is solely managed by Kubernetes.
### Single-node evaluation deployment
A **single-node evaluation deployment** here means a single-server node. This does not imply the deployment of the entire Automation Suite on a single machine. You may have to add additional agent or specialized agent nodes if the entire product suite cannot fit in a single server node, or if you want to run special tasks like Document understanding pipelines, which require GPU capabilities.
The following diagram shows the single-node evaluation deployment.
  ![Single-node evaluation deployment architecture showing server and optional agent node](https://dev-assets.cms.uipath.com/assets/images/automation-suite/automation-suite-docs-image-205691-25e4d4e3.webp)
### Single-node production deployment
A single-node deployment is typically used for evaluation or demo scenarios. In limited cases, it can also be used for production, but only if all of the following conditions are met:
* You must purchase a [UiPath support package](https://www.uipath.com/support/packages-options).
* You must use an external objectstore. For details, refer to [Configure an external objectstore.](https://docs.uipath.com/automation-suite/automation-suite/2.2510/installation-guide/configuring-the-external-objectstore#step-3%3A-configuring-the-external-objectstore)
* You must enable backup. For details, refer to [Backing up and restoring the cluster](https://docs.uipath.com/automation-suite/automation-suite/2.2510/installation-guide/backing-up-and-restoring-the-cluster#backing-up-and-restoring-the-cluster).
* You must configure supported monitoring solutions to enable effective troubleshooting. For details, refer to [Monitoring Automation Suite](https://docs.uipath.com/automation-suite/automation-suite/2.2510/installation-guide/monitoring-automation-suite).
You can later move to a multi-node deployment, by adding new server nodes to the cluster and convert the deployment to multi-node (HA) deployment. For detailed steps, refer to the [Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment](https://docs.uipath.com/automation-suite/automation-suite/2.2510/installation-guide/scaling-a-single-node-evaluation-deployment-to-a-multi-node-ha-deployment#scaling-a-single-node-(evaluation)-deployment-to-a-multi-node-(ha)-deployment) page.
:::important
This configuration does not provide high availability and should be considered only when a multi-node setup is not possible. A multi-node, HA-ready deployment remains the recommended long-term option.
### Lite mode deployment
The **lite mode** is a lightweight deployment that demands less from your infrastructure resources. It provides flexibility with its high configurability for services requiring high availability. By default, the infrastructure and shared components are deployed in HA mode, and all services are in lite mode (horizontal pod autoscaling is enabled with a minimum of one replica).
You can switch specific services to HA mode. You also have the option of performing additional configuration post-deployment to have full HA capabilities.
:::important
You can use lite mode in production, but you must be aware of the implications and risks of having services without high availability enabled.
### Multi-node HA-ready production deployment
A **multi-node HA-ready production deployment** involves 3 or more server nodes behind a load balancer. This is to ensure that, in the event of disaster, when any of the server nodes goes down, Automation suite is still available to perform critical business workflows. It supports both in-cluster and external high availability. The number of agent nodes is optional and is based on actual usage.
The following diagram shows the multi-node HA-ready production deployment.
  ![Multi-node HA-ready production deployment architecture with server and agent nodes behind load balancer](https://dev-assets.cms.uipath.com/assets/images/automation-suite/automation-suite-docs-image-208722-d80e1942.webp)
### High Availability Add-on
In a multi-node setup, High Availability (HA) is enabled by default. However, the Redis-based in-memory cache used by cluster services is running on a single pod and represents a single point of failure. To mitigate the impact of a cache node failure or restart, you can purchase the High Availability Add-on (HAA), which enables redundant, multi-pod deployment of the cache.
For details on how to enable HAA in a multi-node setup, refer to [Enabling High Availability Add-on for the cluste](https://docs.uipath.com/automation-suite/automation-suite/2.2510/installation-guide/high-availability-add-on-configuration#in-cluster-redis-high-availability-add-on-configuration)r.
### Online deployment
An **online deployment** means Automation Suite requires access to the internet during both installation and runtime. All the UiPath® products and supporting libraries are hosted either in UiPath® registry or UiPath-trusted third party store.
You can restrict access to the internet with the help of either a restricted firewall or a proxy server, by blocking all the traffic over the internet other than what is required by Automation Suite. This type of setup is also known as **semi-online deployment**. For details, refer to [Configuring the firewall](https://docs.uipath.com/automation-suite/automation-suite/2.2510/installation-guide/network-requirements#network-requirements) and [Configuring the proxy server](https://docs.uipath.com/automation-suite/automation-suite/2.2510/installation-guide/applying-miscellaneous-settings#optional%3A-configuring-the-proxy-server).
These types of deployments are easier, faster, and require fewer hardware resources to install and manage as compared to [offline deployments](https://docs.uipath.com/automation-suite/automation-suite/2.2510/installation-guide/deployment-architecture#offline-deployment).
The following diagram shows the online deployment model.
  ![Online deployment architecture showing internet connectivity and cloud registry access](https://dev-assets.cms.uipath.com/assets/images/automation-suite/automation-suite-docs-image-464943-0c69c36f.webp)
### Offline deployment
An **offline deployment** (air-gapped) is a completely isolated setup without access to the internet. This kind of setup requires the installation of an additional registry to store all the UiPath® products' container images and binaries, which are shipped in the form of tarball.
The following diagram shows the offline air-gapped deployment model.
  ![Offline air-gapped deployment architecture with isolated registry and no internet connectivity](https://dev-assets.cms.uipath.com/assets/images/automation-suite/automation-suite-docs-image-207646-14ab7e27.webp)
:::note
Uploading binaries (hydration) to the registry introduces additional hardware requirements and installation complexity, increasing the time required to perform an installation as compared to an online deployment.
An offline installation increases not only the complexity during installation, but also the cluster management operations like machine maintenance, disaster recovery, upgrading to newer versions, applying security patches, etc.
You are not allowed to change the deployment method post-installation. This means that you cannot change to offline if the installation is done online and vice versa. It is recommended to choose your deployment strategy after careful consideration.
### Automation Suite architecture
The following diagram depicts the Automation Suite architecture. Note that the Docker registry and the S3-compatible objectstore can also be hosted externally.
  ![Complete Automation Suite system architecture showing all components and external dependencies](https://dev-assets.cms.uipath.com/assets/images/automation-suite/automation-suite-docs-image-621044-ace20764.webp)
The following table lists out the third-party components shipped with Automation Suite:
| Component | Optional/Required | Description |
| RKE2 | **Required** | Rancher-provided Kubernetes distribution. It is the container orchestration platform that runs all the architectural components and services. |
| CEPH Object Store | **Optional**(if you have an external objectstore) | Open-source storage provider that exposes Amazon S3-compliant object/blob storage. It enables services to use blob storage like functionality for their operations. |
| Argo CD | **Required** | Open-source declarative CD tool for Kubernetes. It follows the GitOps pattern of using Git repositories as the source of truth for defining the desired application state. It provides application lifecycle management (ALM) capabilities for Automation Suite components and UiPath® services that run in a Kubernetes cluster. |
| Docker registry | **Optional**(if you have an external registry) | Open-source docker registry used for pushing and pulling install time and runtime container images in your premises. |
| Istio | **Required** | Open-source service mesh that provides functionality such as ingress, request routing, traffic monitoring etc., for the microservices running inside the Kubernetes cluster. |
| Prometheus | **Optional**(you can exclude built-in monitoring components) | Open-source system monitoring toolkit for Kubernetes. It can scrape or accept metrics from Kubernetes components as well as workloads running in the clusters and store those in time series database. |
| Grafana | **Optional**(you can exclude built-in monitoring components) | Open-source visualization tool used for querying and visualizing data stored in Prometheus. You can create and ship a variety of dashboards for cluster and service monitoring. |
| Alertmanager | **Optional**(you can exclude built-in monitoring components) | Open-source tool that helps handling alerts sent by client applications such as the Prometheus server. It is responsible for deduplicating, grouping, and routing them to the correct receiver integrations, such as email, PagerDuty, or OpsGenie. |
| Redis | **Required** | Redis Enterprise non-HA (single shard) used by some UiPath® services to get centralized cache functionality. |
| FluentD and Fluentbit | **Required** | Open-source reliable log scraping solution. The logging operator deploys and configures a background process on every node to collect container and application logs from the node file system. |
| Gatekeeper | **Required** | Open-source tool that allows a Kubernetes administrator to implement policies for ensuring compliance and best practices in their cluster. |
| Velero | **Required<sup>1</sup>** | Open-source tool that allows you to take a snapshot backup and restore. |
| Thanos | **Required** | Open-source tool to push the Prometheus matrix to an objectstore for persistence. |
<sup>1</sup> Only installed during backup and restore.
### External components
You also need to bring a few external components, such as external load balancers and an SQL server. Note that the suite provides some extension points.
