# Configuring NLog
> NLog configuration options and supported logging extensions for Orchestrator in Automation Suite.
## Adding NLog extensions
Orchestrator loads the following extensions by default, so you do not need to include them in the folder or the NLog configuration:
* `NLog.Targets.ElasticSearch`
* `UiPath.Orchestrator.Logs.Elasticsearch`
* `Microsoft.ApplicationInsights.NLogTarget`
* `NLog.Extensions.AzureEventHub`
Only Linux-compatible extensions can be used in this setup, so make sure that your chosen NLog extension abides by this rule.
To make the extension available for use, it must be uploaded to the cluster storage. The `uipathctl` command line tool can do this via the `uipathctl config orchestrator upload` command:
./bin/uipathctl config orchestrator upload --nlog-extensions-directory /path/to/extensions/directory
If you use an external storage configuration at the cluster level, you must indicate this by including the `--is-external-storage` parameter.
## Advanced NLog configuration
### Creating the advanced NLog configuration
1. Create the `nlog.config.json` file containing the standard sections: extensions, targets and rules.
    The extensions section is an array of items that specify the extension assemblies, via `assemblyFile`, and the path of the assembly.
    If custom NLog plugins were loaded (as described in the [Adding NLog extensions](https://docs.uipath.com/automation-suite/automation-suite/2.2510/installation-guide/configuring-nlog#adding-nlog-extensions) section), they will be referenced in the `extensions` section.
2. Configure the target and rule in the `nlog.config.json` file.
3. Apply the `nlog.config.json` file using the `uipathctl` command line tool:
   ./bin/uipathctl config orchestrator update-config --nlog-config nlog.config.json
   :::important
   This action overwrites the existing custom NLog configuration. You can check what the existing configuration is by using this command:
   ./bin/uipathctl config orchestrator get-config --nlog-config
    Example `nlog.config.json` file that writes logs to Azure Blob:
   {   "NLog": {
           "extensions": [
               { "assemblyFile": "NLog.Extensions.AzureBlobStorage.dll" }
           "targets": {
               "azureBlob": {
                   "type": "AzureBlobStorage",
                   "connectionString": "DefaultEndpointsProtocol=https;AccountName=test;AccountKey=key;EndpointSuffix=core.windows.net",
                   "container": "orchestratorlogs",
                   "blobName": "${date:format=yyyy-MM-dd hh.mm}",
                   "layout": {
                     "type": "JsonLayout",
                     "includeAllProperties": true,
                     "Attributes": [
                       {"name": "ts","layout": "${longdate}"},
                       {"name": "level","layout": "${level:upperCase=true}"},
                       {"name": "logger","layout": "${logger}"},
                       {"name": "message","layout": "${message}"},
                       {"name": "exception","layout": "${onexception:${ui-pretty-exception}}"}
           "rules": { "70_Final": { "writeTo": "stdout,azureBlob" } }
    Example `nlog.config.json` file that writes robot logs to Splunk:
       "Nlog": {
           "extensions": [
               { "assemblyFile": "NLog.Targets.Splunk.dll" },
               { "assembly": "UiPath.Orchestrator.Logs.DatabaseBulk.NLogTarget" }
           "targets": {
               "Splunk": {
                   "type": "AsyncWrapper",
                   "overflowAction": "Discard",
                   "queueLimit": 10000,
                   "batchSize": 200,
                   "timeToSleepBetweenBatches": 1,
                   "target": {
                       "type": "SplunkHttpEventCollector",
                       "serverUrl": "http://splunk.example.com",
                       "token": "splunk-token",
                       "channel": "",
                       "source": "${logger}",
                       "sourceType": "_json",
                       "index": "uipath",
                       "retriesOnError": "0",
                       "batchSizeBytes": "0",
                       "batchSizeCount": "0",
                       "includeEventProperties": "true",
                       "includePositionalParameters": "true",
                       "includeMdlc": "true",
                       "maxConnectionsPerServer": "10",
                       "ignoreSslErrors": "false",
                       "useProxy": "false",
                       "proxyUrl": "",
                       "proxyPassword": ""
           "rules": {
               "20_Robot_Primary": { "writeTo": "Splunk,database,insightsRobotLogs" }
### Sizing the Splunk `queueLimit`
The queue absorbs Splunk backlog during slowdowns. Size it to your peak throughput, not your average:
queueLimit = peak_logs_per_sec × acceptable_backlog_seconds
| Deployment | Peak rate | Backlog tolerance | queueLimit |
| Small | ~10 logs/sec | 60 s | `600` |
| Medium | ~35 logs/sec | 300 s | `10000` |
| Large | ~200 logs/sec | 60 s | `12000` |
### Best practices for Splunk targets
* **Use `overflowAction: Discard` for secondary targets.** External log targets such as Splunk are typically analytics or observability destinations, the Orchestrator database is the source of truth. If the external target cannot keep up, dropping its copy is preferable to blocking application threads.
* **Reserve `overflowAction: Block` for targets where loss is not acceptable.** `Block` prevents event loss but does not prevent blocking. When the queue fills under sustained load it reverts to the same thread-blocking behavior as `BufferingWrapper`. Only use it when the external target is a compliance or audit requirement, and size `queueLimit` generously to match peak throughput.
* **Always keep `database` in the `writeTo` rule alongside any external target.** This ensures no robot log is permanently lost regardless of the availability or performance of the external target.
* **Flush before shutdown.** `AsyncWrapper` holds events in an in-memory queue. Ensure NLog targets are flushed on graceful shutdown to avoid losing the tail of the queue when the process exits.
### Updating the advanced NLog configuration
The `uipathctl` commands needed for updating the NLog configuration are:
* `./bin/uipathctl config orchestrator get-config --nlog-config` - Exports the current configuration in a key-value pair json file, ready for editing.
* `./bin/uipathctl config orchestrator update-config --nlog-config nlog.config.json` - Updates the configuration with your changes.
1. Export the current custom NLog configuration to a json file using this command:
   ./bin/uipathctl config orchestrator get-config --nlog-config > nlog.config.json
2. Edit the exported `nlog.config.json` file as needed. You can add, remove, or change any of its settings.
   :::note
   You must export the file again every time you need to make a change, since the update overwrites all NLog settings.
3. Update the NLog configuration using this command:
   orchestrator config updated
