Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
Solutions for prerequisite check failures when Document Understanding modern projects is enabled and AI Center is disabled in Automation Suite on OpenShift.
Description​
When running the prerequisite checks, the process fails if Document Understanding modern projects is enabled and AI Center is disabled in input.json.
Solution​
To address the issue, take the following steps:
  1. Temporarily enable AI Center in input.json by setting aicenter.enabled: true.
  2. Re-run the prerequisite checks.
  3. Verify that all other prerequisite checks pass.
    Note:
    Ignore any errors related to AI Center.
  4. Before running the manifest apply step, revert the configuration by disabling AI Center in input.json.
  5. Proceed with deployment using the manifest apply command.
  • Description​
  • Solution​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
