How to URL-encode a PostgreSQL connection string password
URL-encode special characters in a PostgreSQL connection string password using Python's urllib.parse.quote_plus() on OpenShift.
If your PostgreSQL connection string password contains special characters, you must URL-encode them before including the password in the connection string.
To URL-encode a PostgreSQL password:
  1. Run the following Python command, replacing your_password with your actual password:
    import urllib.parse
    urllib.parse.quote_plus("your_password")
    import urllib.parse
    Python encodes every character except the unreserved set A-Z, a-z, 0-9, -, ., _, ~.
  2. Use the encoded output as the password in your PostgreSQL connection string.
Result​
The command returns the URL-encoded password. For example, urllib.parse.quote_plus("P@ss:w0rd/1") returns P%40ss%3Aw0rd%2F1.
The following table shows common special characters and their percent-encoded equivalents:
CharacterURL encoding
@%40
:%3A
/%2F
?%3F
#%23
%%25
[%5B
]%5D
^%5E
|%7C
space%20
&%26
  • Result​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
