Automation Suite API guide
Switch certificates
Promote the secondary SAML certificate to primary in an Automation Suite organization using the Identity API, including required scope and response schema.
Switch the secondary certificate to become the primary certificate.
API endpoint
POST https://{yourDomain}/{organizationName}/identity_/api/SamlCertificate/{partitionGlobalId}/switch
Scopes
Requires the following scope: PM.AuthSetting.
Request headers
Note:
To obtain the {access_token}, make sure to authenticate through one of the methods described in Authentication methods.
Request body
The request body contains only the organization ID, as partitionGlobalId.
Responses
200 Success
The secondary certificate has been successfully switched with the primary certificate.
  "partitionGlobalId": "3fa85f64-5717-4562-b3fc-2c963f66afa6",
  "primaryCertificateId": 0,
  "primaryCertificate": "string",
  "primaryCertificateThumbprint": "string",
  "secondaryCertificateId": 0,
  "secondaryCertificate": "string",
  "secondaryCertificateThumbprint": "string"
  • API endpoint
  • Scopes
  • Request headers
  • Request body
  • Responses
  • 200 Success
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
