Automation Suite API guide
Get specific group
Retrieve details about a specific group in an Automation Suite organization using the Identity API, including required scope and response schema.
Returns information about a group, based on the organization and group ID.
API endpoint
GET https://{yourDomain}/{organizationName}/identity_/api/Group/{partitionGlobalId}/{groupId}
Scopes
Requires the following scopes:
  • PM.Group
  • PM.Group.Read
Request headers
Note:
To obtain the {access_token}, make sure to authenticate through one of the methods described in Authentication methods.
Path parameters
ParameterData typeDescription
partitionGlobalIdStringRequired.
The ID of the organization containing the desired group.
groupIDStringRequired.
The ID of the group you want to retrieve.
Responses
200 OK
The specified group information is returned.
Example request
Let's say you gathered all the information needed to build the API call.
  • Your {baseURL} is: https://{yourDomain}/{organizationName}/identity_
  • Your {access_token} is: 1234 (for length considerations).
  • The {partitionGlobalId} is: 3fa85f64-5717-4562-b3fc-2c963f66afa6
  • The {groupID} is: 2512
The call should resemble the following example (cURL):
curl --location --request GET 'https://{yourDomain}/{organizationName}/identity_/api/Group/3fa85f64-5717-4562-b3fc-2c963f66afa6/2512' \
Here's the response body for a successful call:
    "id": "2512",
    "name": "Automation Developers",
    "displayName": "Automation Developers",
    "type": 0,
    "creationTime": "2021-10-19T14:25:01.6574988",
    "lastModificationTime": "2021-10-19T14:25:01.6574988",
    "members": [
            "objectType": "DirectoryUser",
            "firstName": "Albus",
            "lastName": "D",
            "jobTitle": "master",
            "companyName": "Hogwarts",
            "city": "London",
            "department": "magic",
            "displayName": "Albus D",
            "source": "local",
            "identifier": "1787ef38-5933-4f2c-a67a-9c22cdb8e6a2",
            "name": "albus",
            "email": "albus@hogwarts.com"
    "id": "2512",
    "type": 0,
    "members": [
            "lastName": "D",
            "city": "London",
            "source": "local",
            "name": "albus",
  • API endpoint
  • Scopes
  • Request headers
  • Path parameters
  • Responses
  • 200 OK
  • Example request
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
