Automation Suite API guide
- Getting started
- Authentication
- Scopes and permissions
- Platform Management APIs
Delete a specific client secret for an external OAuth client in an Automation Suite organization using the Identity API, including required scope and response codes.
Delete a client secret.
API endpoint
DELETE https://{yourDomain}/{organizationName}/identity_/api/ExternalClient/{partitionGlobalId}/secrets/{secretId}
Scopes
Requires either one of the following scopes:
PM.OAuthAppPM.OAuthApp.WritePM.OAuthAppSecret.Write
Request headers
Note:
To obtain the {access_token}, make sure to authenticate through one of the methods described in Authentication methods.
Request body
The request body contains the organization ID, and the ID of the client secret you want to delete.
"partitionGlobalId": "<organizationId>",
"secretId": "<secretId>"
Responses
204 No content
The client secret has been successfully deleted. No value is returned.
