Automation Suite API guide
Allocate licenses to a group
Allocate licenses to a group in an Automation Suite organization using the License Management API, including required scope and request body fields.
As an organization admin, use this endpoint to allocate licenses to a group. To do that, you need to create an external application, with the scope PM.License.Write.
API endpoint
PUT https://{yourDomain}/{organizationName}/lease_/api/account/{accountId}/user-license/group/{groupId}
Request headers
Note:
To obtain the {access_token}, make sure to authenticate through the ROPC method described in Authentication methods.
Path parameters
ParameterData typeDescription
accountIdStringRequired.
The ID of the organization in which your tenant resides.
groupIdStringRequired.
The ID of the group you want to allocate licenses to.
You can retrieve this ID by following these steps.
Request body
The request body contains the array of license codes for various products and their corresponding quantity.
    "userBundleCodes": ["string"]
Note:
  • To see the available user bundle codes you may use in the request body, check out the user license codes.
  • You may allocate as many licenses as the organization has purchased.
Responses
200 OK
Returns the allocated group licenses.
404
No account license is allocated for the indicated organization.
Example request
Let's say you gathered all the information needed to build the API call.
  • Your {baseURL} is: https://{yourDomain}/{organizationName}.
  • Your {access_token} is: 1234 (for length considerations).
  • The {accountId} of the tenant that needs license allocation is: song-one
  • The {groupId} is: group-01.
  • You want to allocate user licenses to the group as follows:
The call should resemble the following example (cURL):
curl --location --request POST 'https://https://{yourDomain}/{organizationName}/lease_/api/account/1234/user-license/group/group-01' \
--header 'Content-Type: application/json' \
--data-raw '{
    "userBundleCodes": ["RPADEVPRONU", "IDU", "CTZDEVCU"],
    "useExternalLicense": false
--data-raw '{
Here's the response body for a successful license allocation:
  "groupId": "string",
  "organizationId": "string",
  "useExternalLicense": false,
    "string"
    "string"
  • API endpoint
  • Request headers
  • Path parameters
  • Request body
  • Responses
  • 200 OK
  • 404
  • Example request
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
