# Switching between Active Directory adapters
> Switch between the ad and ldapad Active Directory adapters in Automation Suite Identity Server, including compatibility differences and how to identify the current adapter type.
UiPath® Identity Server provides support for two Active Directory adapters: `ad` and `ldapad`.
* `ad` adapter: Legacy adapter that works only in standalone deployments. The `ad` adapter only operates on Windows and it supports external trust domains and NTLM, offering support for non-domain joined clients to authenticate.
* `ldapad` adapter: Adapter introduced in 2021.10. The `ldapad` adapter works in both standalone and Automation Suite deployments and it does not support external trust domains and NTLM for non-domain joined clients to authenticate.
The following table describes the two Active Directory adapters for each deployment model:
| Deployment | `ad` adapter | `ldapad` adapter |
| Automation Suite | Not supported | Supported |
:::note
All deployments prior to 2021.10 with Active Directory integration enabled keep the `ad` adapter after upgrade. All other deployments get, by default, the `ldapad` adapter when Active Directory integration is enabled.
## Checking the Active Directory adapter type
To determine the adapter type, a SQL query can be executed which checks the type of the adapter in the `[identity].[DirectoryConnections]` table.
SELECT dc.* from [identity].[DirectoryConnections] dc
JOIN [identity].[Partitions] p ON p.[Id]=dc.[PartitionId]
WHERE p.[GlobalId]='FEB0DD79-85B6-483B-B297-0E49A1AA5B7D' AND dc.[IsDeleted]=0
If `[Type]=ad`, then the `ad` adapter is in use. If `[Type]='ldapad'`, then the `ldapad` adapter is in use.
## Switching from `ldapad` to `ad`
:::note
This is supported only in standalone deployments.
To switch from `ldapad` to `ad`, take the following steps:
1. Check that `ldapad` adapter is enabled by making sure the following query returns one row:
   SELECT dc.* from [identity].[DirectoryConnections] dc JOIN [identity].[Partitions] p ON p.[Id]=dc.[PartitionId] WHERE p.[GlobalId]='FEB0DD79-85B6-483B-B297-0E49A1AA5B7D' AND dc.[Type]='ldapad' AND dc.[IsDeleted]=0
2. Connect to the Orchestrator/Identity database and run the following script, making sure to replace `FQDN-OF-DOMAIN` with the fully qualified name of the default/main domain. With Active Directory integration enabled in the UiPath host portal, the following SQL script updates the `DirectoryId` of Active Directory users and groups, soft-deletes `ldapad` directory connections, and creates `ad` directory connections.
   -- convert users
   IF OBJECT_ID('tempdb..#tmp_ldap_users') IS NOT NULL
   DROP TABLE #tmp_ldap_users
   SELECT [Id], [MasterPartitionId], CONCAT('ad', SUBSTRING([DirectoryId], 7, 256)) AS [DirectoryId] INTO #tmp_ldap_users
   FROM [identity].[AspNetUsers]
   WHERE [DirectoryId] LIKE 'ldapad|%' AND [IsDeleted]=0
   --SELECT * FROM #tmp_ldap_users
   DELETE tmp
   FROM #tmp_ldap_users tmp
   JOIN [identity].[AspNetUsers] u ON u.[MasterPartitionId]=tmp.[MasterPartitionId] AND u.[DirectoryId]=tmp.[DirectoryId]
   UPDATE u
   SET u.[DirectoryId]=tmp.[DirectoryId]
   FROM [identity].[AspNetUsers] u
   JOIN #tmp_ldap_users tmp on tmp.[Id]=u.[Id]
   -- create 'ad' directory connection
   DECLARE @HostPartitionId int        -- host partition id
   SELECT @HostPartitionId = [Id] FROM [identity].[Partitions] WHERE [GlobalId]='FEB0DD79-85B6-483B-B297-0E49A1AA5B7D'
   UPDATE [identity].[DirectoryConnections] SET [IsDeleted]=1, [DeletionTime]=GETUTCDATE() WHERE [PartitionId]=@HostPartitionId AND [Type]='ldapad' and [IsDeleted]=0
   SELECT * FROM [identity].[DirectoryConnections] WHERE [PartitionId]=@HostPartitionId AND [Type]='ad' and [IsDeleted]=0
   IF @@ROWCOUNT=0
       INSERT INTO [identity].[DirectoryConnections] ([PartitionId], [Type], [CreationTime], [Configuration], [IsDeleted])
       VALUES (@HostPartitionId, 'ad', GETUTCDATE(), '{ "Domain": "<FQDN-OF-DOMAIN>" }', 0)
   SELECT * FROM [identity].[DirectoryConnections] WHERE [PartitionId]=@HostPartitionId AND [IsDeleted]=0
3. Restart the Identity application pool by running `iisreset` from an elevated prompt.
## Switching from `ad` to `ldapad`
To switch your directory integration from `ad` to `ldapad`, follow these steps:
1. Check that the `ad` adapter is enabled by making sure the following query returns one row:
   WHERE p.[GlobalId]='FEB0DD79-85B6-483B-B297-0E49A1AA5B7D' AND dc.[Type]='ad' AND dc.[IsDeleted]=0
2. In the host portal, delete the existing Active Directory integration.
3. Reconfigure the directory integration, and under **Directory integration** select **Configure**.
   :::note
   When you switch from `ad` to `ldapad` all user settings and permissions are preserved, even during the delete and reconfigure steps.
4. Restart the IIS services.
For example, you can use the `iisreset` command in the Command Prompt to reset the IIS services.
