# Checking usage summary
> View LLM usage data by model, region, status, and product on the AI Trust Layer Usage Summary tab in Automation Suite.
## Checking usage summary
The **Usage Summary** tab on the **AI Trust Layer** page provides an overview of the model usage and restrictions across different regions. It represents the historical data from your audit log and reflects the settings of your governance policies.
You can view data displayed on the following criteria:
* **Total LLM Actions per Status**: Enables you to monitor the status of different models across regions. To customize the data visualization, you can filter by region, model, status, and source.
* **Total LLM Actions per Product**: Allows you to monitor the AI feature adoption within your organization. To customize the data visualization, you can filter by tenant and product.
