Automation Hub
- Release Notes
- Getting Started
- Permissions
- Starting as
- Admin Console
- Workspace
- Explore
- Dashboards
- Share Idea or Automation
- My Tasks
- Notifications
- Resources
- Task Capture Integration
- Automation Store
- Email Notifications
- Video Tutorials
- Additional Resources
Starting as an RPA Sponsor
Automation Hub User Guide
Last updated Sep 19, 2023
After successfully logging in, you, as an RPA Sponsor, can check out the list of the Ideas and Components submitted within your tenant.
You are encouraged to Share your own ideas or components that will boost the company’s RPA assimilation as well as keep an eye on the tenant evolution through the Dashboards module.
Within the Workspace module, you can have a detailed view over:
- Your ideas;
- Your collaborations;
- Your components;
- The Automation Pipeline;
- The Ideas you follow.
By accessing the Explore module you can:
- view the ideas shared by your colleagues and choose to follow the ones that drow your attention,
- check out and download the components shared within your tenant,
- access the Leaderboard.
