Automation Hub
- Release Notes
- Getting Started
- Permissions
- Starting as
- Admin Console
- Workspace
- Explore
- Share Idea or Automation
- Dashboards
- My Tasks
- Notifications
- Email Notifications
- Resources
- Process Mining Integration
- Studio Integration
- Task Capture Integration
- Automation Hub - Automation Cloud Integration
- Automation Store
- Additional Resources
Automation Hub User Guide
Last updated 14. März 2024
Components
The Add Component button is available only for the Process Owner, Project Manager, and the collaborators with editing rights in the Components section and allows them to update the Automation Idea Profile with reusable components that can further be used to implement the described process.
As soon as you click the Add Component button a pop-up page is displayed allowing you to Search in the tenant's component database and select the component you want to add to the Automation Idea Profile.
