# Input for Category
> Category ID input rules for Automation Hub API calls, including how hierarchy chaining works using the lowest-level category ID.
:::note
Use the lowest Category ID in order for the whole hierarchy chain to be inputted.
| Key | Value | Use Case |
| **hierarchy** | The Category values are not defined as these fields are customized by each tenant. | GET and POST request parameters |
:::note
You can easily extract the Category values relevant for your tenant by using the GET category call.
**Example: "category=717**" where 717 is a level 3 Category used in order to input the whole Category chain (the Level 1 Category, the Level 2 Category, and the Level 3 Category).
## UI Correspondent
* Categories
