# Submit an Idea
> If you notice a manual, repetitive task, or process that could be done automatically, you are encouraged to submit an idea. Do this by clicking the **Submit idea** button available on the top, right-hand side of the page.
![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-docs-image-148617-4b7d9541-647ef41e.webp)
As per your current permissions, you are now asked to select a **Business Area** for your idea. From the dropdown list, choose one that applies. Continue with a Category, Sub-Category, if the case. Based on the selection and according to your permissions, the system loads the list with available idea flows (e.g. Employee-driven idea, CoE driven idea, Citizen Developer automation, Change request) that can be selected in **Idea type**.
:::note
Depending on your permissions, if you have one single option for submitting an idea, in the list of idea types you might see only one option.
## Employee-driven Idea
The Employee-driven idea option from **Submit new** form is available for users with a limited amount of information related to the process/task they are describing, and are not so familiar with RPA.
Based on the selection and according to your permissions, the system loads the list with available idea flows (e.g. Employee-driven idea, CoE-driven idea, Agentic AI idea, Citizen Developer automation, Change request) that can be selected in Idea type.
If you're not sure that the chosen task/process is suitable, follow the submission process as it's created to help you decide, and, at the same time, you will become more familiar with the criteria used for assessing a task/process. To test an idea, it first needs to be shared.
As soon as you shared an idea the below flow is initiated:
1. The platform automatically calculates the Idea Score.
2. An Idea Profile is created. Check it to follow its evolution and updates.
3. The idea undergoes several reviews and updates. Check out the [Idea Review Phases](https://docs.uipath.com/automation-hub/automation-suite/2.2510/user-guide/automation-idea-review-phases#idea-review-flow) for more information.
Below you can find a graphic display of the Employee-driven idea flow:
![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-docs-image-Employee-driven-9e195eda-f568f155.png)
For a review flow where the infographic is explained, see [Employee-driven Idea](https://docs.uipath.com/automation-hub/automation-cloud/latest/user-guide/automation-idea-review-phases#employee-driven-idea).
## Submitting a CoE-driven Idea
Authorized users like Subject Matter Experts, Process Owners, RPA Business Analysts, Process Consultants who know the process in detail, can bypass the Idea Approver's approval flow by sharing a CoE-driven idea. Check out the [Idea Review Phases](https://docs.uipath.com/automation-hub/automation-suite/2.2510/user-guide/automation-idea-review-phases#idea-review-flow) for more information.
Below you can find a graphic display of the CoE-driven idea flow:
![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-docs-image-CoE-driven-21a3c7ed-0423ae6e.jpg)
### How to submit a CoE-driven Idea
To start the process click the **Submit idea** button available on the top, right-hand side of the page.
![Submit new](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-submit-new-649504-949260fd-8ae47f28.webp)
On the selection screen, choose **Idea** to proceed with submitting an automation opportunity.
As per your current permissions, you are now asked to select a **Business Area** for your automation. From the dropdown list, choose one that applies. Continue with a Category, Sub-Category, if the case. Based on the selection and according to your permissions, the system loads the list with available idea flows (e.g. Employee-driven idea, **CoE-driven idea**, Citizen Developer automation, Change request, Agentic AI idea) that can be selected in **Idea type**.
:::important
Make sure you have the needed permissions in order to use this feature, as noted in the [CoE-driven Idea](https://docs.uipath.com/automation-hub/automation-suite/2.2510/user-guide/submit-an-idea#submit-an-idea) section.
