# My Components
> :::note
This option may not be displayed if the Company Admin decides to switch it off from the **Settings** page. For details please check the [Updating the Settings page](https://docs.uipath.com/automation-hub/automation-suite/2.2510/user-guide/updating-the-settings#updating-the-settings).
:::note
When accessing this page you have two lists containing the details for:
1. components you uploaded (created);
2. components you downloaded.
The components from each list are displayed in a tabular view that has the following options available:
* **Search** for a particular component.
* **Sort** the components you want to view by applying the available filters.
* **Show/Hide** the columns from the list.
The **Upload Component** option allows you to add to the tenant components you created. These will be valuable assets during the idea review and implementation process. Please check the [Uploading a Component](https://docs.uipath.com/automation-hub/automation-suite/2.2510/user-guide/uploading-a-component#uploading-a-component) page for the step by step process.
:::note
The **Upload Component** option is also available when accessing the Explore > Explore Components module.
