# Component Statuses
> <table cellpadding="4" cellspacing="0">
 <colgroup>
  <col/>
  <col/>
  <col/>
 </colgroup>
 <thead>
  <tr>
   <th> <p> Status </p> </th>
   <th> <p> Component Visible for </p> </th>
   <th> <p> Description </p> </th>
  </tr>
 </thead>
 <tbody>
  <tr>
   <td> <p> Draft </p> </td>
   <td> <p> Author </p> </td>
   <td>
      <ul>
        <li> The author uploaded a component but does not submit it. </li>
        <li> The curator rejected the component in the curation flow with - needs update reason. </li>
        <li> The author submitted the component but then withdrawn it. </li>
      </ul>
</td>
  </tr>
  <tr>
   <td> <p> Submitted </p> </td>
   <td> <p> Author </p><p> Component Curators </p> </td>
   <td> <p> The author has uploaded a component and submit it. The component remains in this state until the curation process is initiated. </p> </td>
  </tr>
  <tr>
   <td> <p> In Review </p> </td>
   <td> <p> Author </p><p> Assigned Component Curator </p> </td>
   <td> <p> The curator has picked-up the component from the Manage Components list and started curating it. </p> </td>
  </tr>
  <tr>
   <td> <p> Published </p> </td>
   <td> <p> All Users </p> </td>
   <td> <p> The curator finishes the curation process and decides to publish the component. </p> </td>
  </tr>
  <tr>
   <td> <p> Rejected Permanently </p> </td>
   <td> <p> The curator finishes the curation process and decides to permanently reject the component. </p> </td>
  </tr>
  <tr>
   <td> <p> Rejected Needs Update </p> </td>
   <td>
      <ul>
        <li> The curator finishes the curation process and decides to send the component back to the author with recommendation for updates. </li>
        <li> The status is similar to the draft one, only that this one is used to warn the author that they need to update the component before submitting the component again. </li>
      </ul>
</td>
  </tr>
  <tr>
   <td> <p> Archived </p> </td>
   <td> <p> Author </p><p> Users who have downloaded the component </p> </td>
   <td> <p> The author decides to archive the component from My Components - uploads. </p> </td>
  </tr>
 </tbody>
</table>
<colgroup>
  <col/>
  <col/>
  <col/>
 </colgroup>
     Status
     Draft
     Author
     Submitted
     Author  Component Curators
     In Review
     Author  Assigned Component Curator
     Published
     All Users
     Archived
     Author  Users who have downloaded the component
