# Submit an Automation Flow
> As soon as you submit an automation, the below flow is initiated:
1. An Automation Profile is created for your automation. Check it to follow its evolution and updates.
2. The automation undergoes several reviews. This depends on your assigned permission level. Check out the for more information.
Below you can find a graphic display of the Citizen Development automation flow:
   ![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-docs-image-CITIZEN%20DEVELOPER%20FLOW-eb1f99e8-925afb5c.png)
