# Automation Hub - Task Mining Integration
> Applies to Automation Cloud only.
This feature empowers you to create a **UiPath Task Mining** project directly from the **UiPath Automation Hub** interface. This integration streamlines the process of initiating task mining projects, allowing you to seamlessly transition from identifying automation opportunities to collecting and analyzing user behavior data.
## Enabling the integration
**To enable the integration,** you must meet the following prerequisites::
* In **Automation Cloud** you need to be an **Organization Admin** - to manage tenant level services and add the service if it isn't there.
* In **Automation Hub** you need to have the **Manage the Tenant Settings** permission to enable/disable the integration.
  ![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-docs-image-332679-76656491-1e403a66.webp)
  :::note
  The integration might be enabled by default. The following are the default statuses for the integration:
  * Existing tenants with Automtion Hub and Task Mining - integration on by default.
  * Existing tenants with Automation Hub and no Task Mining - integration is turned on when Task Mining is enabled.
  * Existing tenants with only Task Mining - integration is turned on when Automation Hub is enabled.
  * New tenants with Automation Hub and Task Mining - integration on by default.
  * New tenants and existing tenant without Task Mining or Automation Hub - integration on by default.
1. In **Automation Hub** platform, select **Admin console**.
2. Select the **Account** tab, and from the dropdown list, select **Settings**.
3. In the **Features Toggles** section, check if **Capturing process graphs with Task Mining** is enabled. The option is grayed out if **Task Mining** isn't present at the tenant level.
4. Choose the **Default tool for capturing process graphs**, by selecting one of the options available.
   ![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-docs-image-332674-3fbf189c-a82805ba.webp)
## Using the integration
To use the integration from an existing idea, perform the following steps:
1. In the Documentation tab from an Automation Profile, select the arrow, and from the dropdown list, select the tool you want to use for documenting the idea between **Task Mining** or **Task Capture**. Select **Capture with Task Mining**. A new project is automatically created in **Task Mining**, and after saving the flow, the information is sent to **Automation Hub**.![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-docs-image-332684-77d59b09-6023094a.webp)
   :::note
   To use **Task Mining** to document the process, you need **Project Creator** role in **Task Mining** to be able to create a project.
2. Once the project is created in **Task Mining**, a confirmation message is displayed in Automation Hub and the link is available in the **Links** section from the right hand side, above **Basic Information** section.
   :::note
   If a **Task Mining** project is already linked to an **Automation Hub** idea, when using export, you can view the Idea name and exported traces so you know that the idea is already mapped.
   ![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-docs-image-332727-9edc04ab-a71d705c.webp)
## Existing documents
For existing **Task Capture** documents, you can still use the **Edit with Task Capture** option to update your project. This is also applicable if **Task Mining** is set as the default option for creation.
   ![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-docs-image-325129-b3ae7fa1-bb4db94d.webp)
