# Input for High Level Assessment
> Used for Submitting the Employee-driven Ideas
 <colgroup>
  <col/>
  <col/>
  <col/>
  <col/>
 </colgroup>
     Key
     Value
     Use Case
     Mandatory?
     How rule-based is your task? = rules
          Very Creative = 1
          Pretty Creative = 2
          A mix between rules and creativity = 3
          Pretty Rule Based = 4
          Very Rule Based = 5
     GET and POST request parameters
     Yes
     How would you describe the input data for your task/process? = input_type
          Very Much Paperbased = 1
          Pretty Much Paperbased= 2
          A mix between digital and paperbased = 3
          Pretty Much Digital = 4
          Very Much Digital = 5
     Yes
     How would you describe the structure of your input data? = input_quality
          Very much unstructured = 1
          Pretty much unstructured = 2
          A mix between structured and unstructured = 3
          Pretty Much Structured = 4
          Very Much Structured = 5
     Yes
     Are you aware of any expected changes to the way you currently perform the activity or process in the following 6 months? = stability
          Major Change Expected = 1
          Several Changes Expected = 2
          Some Change Expected = 3
          Minor Change Expected = 4
          No Change Expected = 5
     Yes
     Do you have any documentation regarding this process/activity?= documentation
          Detailed Work Instructions = 5
          Standard Operating Procedure = 4
          Task/Process maps/flowcharts = 3
          Input Files = 2
          There is no documentation = 1
     Yes
     The Idea submitter submitter
     Enter the submitter email address.
    &nbsp;
     Yes
     The idea assigned Process Owner owner
     Enter the Process Owner email address.
    &nbsp;
     Yes
     Automation Idea Name = process_name
     Enter the name of the idea using the template.
     Yes
     Description = process_description
     Enter the idea description using the template.
     Yes
     Automation Idea Area = category_id
     You can easily extract Category ID by using the  GET category  call.
     Yes
Example:
  "process_name": "InvoiceProcessing",
  "process_description": "Invoice data entry",
  "category": 717,
    "rules": 4,
    "input_type": 3,
    "input_quality": 5,
    "stability": 4,
    "documentation": 5,
    "submitter": "jane.doe@email.com",
    "owner": mary.doe@email.com1
**UI Correspondent:** Submit an Idea
