# Best practices for using mobile device manager
> This page provides practical guidelines to help you use the mobile device manager
efficiently for managing devices and applications.
## Improving connection efficiency for emulators and real devices
Follow these steps to speed up connections with local emulators or real devices by
skipping the repeated installation of your test application:
1. Open the device in mobile device manager.
   :::note
   Ensure the device is either a local emulator or a real device.
2. In the **Appium Desired Capabilities** section, add the
   `skipUninstall` capability and set it to
   `True`.
   This capability prevents mobile device manager from
   uninstalling the application when the connection closes, removing the need
   to reinstall it when reconnecting.
3. If you need to test a newer version of the application:
   1. Set `skipUninstall` to `False` for the
      initial connection to allow the application update.
   2. After completing the update, set `skipUninstall` back to
      `True`.
## Improving WebView performance
Use these **Appium desired capabilities** to optimize the loading of WebView
applications or elements on devices in mobile device manager:
* General capabilities:
  + Set `skipServerInstallation` to
    `True`.
* Android capabilities:
  + Set `disableAndroidWatchers` to
    `True`.
  + Set `ignoreUnimportantViews` to
    `True`.
* iOS capabilities:
  + Set `useJSONSource` to `True`.
  + Set `shouldWaitForQuiescence` to
    `False`.
  + Set `simpleIsVisibleCheck` to `True`.
