Studio
- Release Notes
- Getting Started
- Setup and Configuration
- Automation Projects
- Dependencies
- Types of Workflows
- File Comparison
- Automation Best Practices
- Source Control Integration
- Debugging
- The Diagnostic Tool
- Workflow Analyzer
- About Workflow Analyzer
- ST-DBP-023 - Empty Workflow
- ST-USG-032 - Required Tags
- Variables
- Arguments
- Imported Namespaces
- Recording
- UI Elements
- Control Flow
- Selectors
- Object Repository
- Data Scraping
- Image and Text Automation
- Automating Citrix Technologies
- RDP Automation
- Salesforce Automation
- SAP Automation
- VMware Horizon Automation
- Logging
- The WebDriver Protocol
- Test Suite - Studio
- Extensions
- Troubleshooting
- About troubleshooting
- Microsoft Office issues
Example of Using OCR and Image Automation
Studio User Guide
Last updated May 13, 2024
Since OCR and Image automation usually go hand in hand due to the difficulty of automating in virtual environments, we created an automation that retrieves an employee’s email and the invoice number from a scanned invoice. Afterwards, it inputs the information into a dummy expense app (ExpenseIt) on a virtual machine, and compares the total from the invoice with the one in the app:
Since this automation involves connecting to a virtual machine, uploading the original project is redundant, as it would not work on another machine. We encourage you to build your own project by following the above steps.
