Solutions Management
- Introduction
- Getting started
- Managing solution projects and packages
- Managing solution deployments
Uninstalling a solution
Solutions Management User Guide
Last updated May 17, 2024
You can remove a solution deployment from a tenant by uninstalling it in an automated manner. The uninstall operation removes from the system everything that was created as part of the deployment, including the solution folders. Note that you cannot undo the uninstall operation.
To uninstall a solution, take the following steps:
- In the Solutions Management view, select the tenant you want to uninstall from your solution from.
- In the Deployments tab, find the solution you want to uninstall, select the three-dot menu corresponding to it, then choose Uninstall.
- Type the name of the solution deployment in the newly open window to confirm the action, then select Uninstall.
