- Overview
- Excel
- Release Notes
- About the Excel activity package
- Project Compatibility
- Project Settings
- Use Excel File
- Append Range
- Auto Fill
- Autofit Range
- Change Pivot Data Source
- Clear Sheet/Range/Table
- Copy/Paste Range
- Create Pivot Table
- Delete Column
- Delete Rows
- Delete Sheet
- Duplicate Sheet
- Export to CSV
- Fill Range
- Filter
- Filter Pivot Table
- Find First/Last Data Row
- Find/Replace Value
- For Each Excel Row
- For Each Excel Sheet
- Format As Table
- Format Cells
- Get Excel Chart
- Insert Column
- Insert Chart
- Insert Rows
- Insert Sheet
- Lookup
- Match Function
- Protect Sheet
- Read Cell Formula
- Read Cell Value
- Read Range
- Refresh Excel Data Connections
- Refresh Pivot Table
- Remove Duplicates
- Rename Sheet
- Run Spreadsheet Macro
- Save Excel File
- Save Excel File As
- Save Excel File As PDF
- Sort Range
- Text to Columns
- Unprotect Sheet
- Update Excel Chart
- VLookup
- Write Cell
- Write CSV
- Write DataTable to Excel
- Get Cell Color
- Invoke VBA
- Select Range
- Get Selected Range
- Excel Application Scope
- Append To CSV
- Read CSV
- Write CSV
- Delete Column
- Filter Table
- Get Table Range
- Insert Column
- Sort Table
- Append Range
- Close Workbook
- Get Cell Color
- Read Cell
- Read Cell Formula
- Read Column
- Read Range
- Read Row
- Select Range
- Set Range Color
- Write Cell
- Write Range
- Save Workbook
- Create Table
- Get Workbook Sheet
- Get Workbook Sheets
- Copy Sheet
- Delete Range
- Auto Fill Range
- Copy Paste Range
- Execute Macro
- Insert/Delete Columns
- Insert/Delete Rows
- Invoke VBA
- LookUp Range
- Remove Duplicates Range
- Excel Process Scope
- Manage CSV Files
- Filter CSV Files
- Verify CSV Files
- Table Functions
- Manage Multiple Excel Files
- Interpret Excel Results
- Manage Pivot Tables
- Manage Range Selection
- Read From Excel Files
- Manage Databases in Excel
- Compare CSV Files
- Compare Numeric Values
- Sort Data in Excel Files
- Filter and Delete Rows in Excel Files
- Manipulate Range Selections
- Verify Excel Workbook Data
- Read, Write, and Append Data in Excel
- Google Workspace
- Release notes
- About the Google Workspace activities package
- Project compatibility
- Add Attendee
- Create Event
- Delete Event
- Modify Event
- Search Events
- Use Google Drive
- Share File
- Delete File Permission
- Get File Permissions
- Update File Permission
- Copy File
- Create Folder
- Delete File
- Download File
- Find Files and Folders
- Get File Info
- Move File
- Upload File
- Create Document
- Create New Spreadsheet
- Get Mail Messages
- Send Mail Messages
- Change Labels
- Use Google Spreadsheet
- Add Delete Columns
- Add Delete Rows
- Auto Fill Range
- Add New Sheet
- Append Row
- Batch Spreadsheet Updates
- Copy Sheet
- Copy Paste Range
- Delete Range
- Delete Sheet
- Get Cell Color
- Get Sheets
- Read Cell
- Read Column
- Read Range
- Read Row
- Rename Sheet
- Write Cell
- Write Range
- Clear Range
- Download Spreadsheet
- Use Google Document
- Batch Document Updates
- Get Document
- Get Text Index
- Insert Text
- Replace Text
- Read All Text
- Create Script Project
- Get Project Content
- Upload Script File
- Create Deployment
- Run Script
- Mail
- Microsoft 365
- Release notes
- About the Microsoft 365 activities package
- Connections
- AddEmailCategories
- ArchiveEmail
- DeleteEmail
- DownloadEmail
- DownloadEmailAttachment
- DownloadEmailAttachments
- ForwardEmail
- GetEmail
- GetEmailAttachmentsInfo
- GetEmails
- GetMailFolders
- GetNewestEmail
- MarkEmailAsRead
- MarkEmailAsUnread
- MoveEmail
- RemoveEmailCategories
- ReplyToEmail
- SendEmail
- TurnOffAutomaticReplies
- TurnOnAutomaticReplies
- Merge multiple sheets into a new summary Excel sheet
- Automatically accept calendar invites from your manager
- Move files to dedicated folders by type
- Verify if new employment documents (I9 and ID) match
- Add new customers to a SharePoint List
- Delete SharePoint List items newer than yesterday
- Notify me on Slack when an important Outlook Email is received
- Include creation date in new OneDrive file names
- Notify me by email when a new file is created
- Add Sheet
- Append Range
- Clear Range
- Copy Range
- Copy Sheet
- Create Workbook
- Delete Range
- Delete Sheet
- Get Cell Color
- Get Sheets
- Read Cell
- Read Column
- Read Range
- Read Row
- Rename Sheet
- Write Cell
- Write Range
- Set Range Color
- Create Table
- Get Table Range
- Insert Column
- Delete Column
- Insert Rows
- Delete Rows
- VLookup Range
- Use OneDrive & SharePoint
- Copy File/Folder
- Create Folder
- Delete File/Folder
- Download File
- Export File as PDF
- Find Files And Folders
- Get File/Folder
- Move File/Folder
- Upload File
- Share File/Folder
- For Each File/Folder
- Forward Mail
- Get Mail
- Move Mail
- Send Mail
- Reply to Mail
- Delete Mail
- Set Mail Categories
- Add Attachment
- Add Attendee
- Add Location
- Create Event
- Delete Event
- Find Meeting Times
- Get Calendars
- Modify Event
- RSVP
- Search Events
- Create Group
- Delete Group
- Get Group
- List Groups
- Create Bucket
- Delete Bucket
- List Buckets
- List Bucket Tasks
- Create Plan
- Get Plan
- List Plans
- Create Task
- Delete Task
- Get Task
- List Tasks
- Update Task
- For Each List
- Get List Info
- For Each List Item
- Delete List Item
- Add List Items
- Update List Item
- Get List Items
- Presentations
- Word
Use PowerPoint Presentation
UiPath.Presentation.Activities.PowerPointApplicationScope
Lets you select a PowerPoint presentation to use in the automation. After you add the activity and indicate the file, add the PowerPoint activities to perform on the presentation inside this activity. If the specified file does not exist, it can be created by the automation.
You can add UI Automation activities directly in the Use PowerPoint File activity to quickly automate the interface of PowerPoint. For this to work, you need to have the PowerPoint file open on your machine.
In the Body of the Activity
PowerPoint file - Click Browse next to the field, and then browse to and select a PowerPoint file to use in the automation.
To create a new file when the automation is executed, browse to the folder where to create it, enter the file name, and make sure to select the Create if needed option.
If you need to work with a file with a dynamic name, you can provide the file path using one of the options in the Plus menu on the right side of the field. For example, select a cell in the Project Notebook where the file path can be extracted daily using the provided formulas, or select Ask when run to enter the path of the file when executing the project. Alternatively, you can work with a remote PowerPoint file by inputting the SharePoint URL of the file.
- Reference as - Enter a name by which to refer to the file in the automation project.
- Save changes - Saves the presentation on each change caused by an activity. If disabled, the changes are saved only after all the activities added inside Use PowerPoint Presentation are executed. This option is selected by default.
- Create if not exists - When selected, if the specified presentation file does not exist, a new presentation is created. When not selected, an error occurs if the presentation file cannot be found. This option is not selected by default.
Template file - When you use this activity to create a new file, or the path in the Presentation file field is dynamic, you can select this option to use another PowerPoint file with the same structure at design time. The data in the template file is available for selection from the Plus menu in activities added inside Use PowerPoint Presentation, enabling you to easily configure them by selecting slides, placeholders, or layouts directly from StudioX.
After you select this option, click Browse to select the file to use as a template.
Note: The template file is used only at design time and no content is copied from its slide master. When the automation is executed, it processes the file defined in the Presentation file field.
Properties Panel
Common
- DisplayName - The name displayed for the activity in the Designer panel.
File
- Edit password - The password required for editing the PowerPoint presentation, if the file is password-protected.
- Password - The password required for opening the PowerPoint presentation, if the file is password-protected.
- Path - The path to the PowerPoint presentation. If the file does not exist and you select the Create new file option, the file is created when the automation is executed.
Misc
- Private - If selected, the values of variables and arguments are no longer logged at Verbose level.
Options
- Auto save - See Save changes in the body of the activity.
- Create new file - See Create if not exists in the body of the activity.
- Read only - If selected, the specified presentation is opened in Read-Only mode. Selecting this check box enables you to perform data extraction operations in a file which is locked for editing or has an edit password. This option is not selected by default.
- Use template file - See Template file in the body of the activity.
