Automation Hub
Banner background image
Automation Hub API Guide
Last updated May 30, 2024
Permissions Per Endpoint
Admin Console
Note: The Open API permission system works by the same principles of the one included in the Automation Hub interface.When an API token is generated with a user associated to it, then the permissions of that user will be reflected in the API calls he can perform via the Open API.
Action
Permissions
Token Type
GET - /hierarchy
Open endpoint that can be accessed by all users, regardless of their permissions in the interface.
Personal TokenUser Assigned TokenTenant Level Token
GET - /appinventory
GET - /users
All users with the Manage Users permission
POST - /adduser
POST - /edituser
All users with the Manage Users Roles permission
GET - /roles
All users with the Manage Users role
Automation Ideas
Action
Permissions
Token Type
GET - /automations
Is limited based on user's permissions to specific categories. For example: if a user is has a "Standard User" permission that applies to "Legal", GET Automations will display all the automations in "Legal".
POST - /automationidea
All users that are allowed to submit Employee Driven ideas as per the permission in the interface.
Personal TokenUser Assigned Token the call works only if you define a submitter in the Body
POST - /coe-automationidea
All users that are allowed to submit CoE Driven ideas as per the permission in the interface.
POST - /automations/status
All users that are allowed to Edit details of ideas as per the permission in the interface.
GET - /cba
All users that are allowed to View details of the Cost Benefit Analysis as per the permission in the interface.
GET - /collaborators
All users that are allowed to View Idea Collaborators as per the permission in the interface.
Automation Pipeline
Action
Permissions
Token Type
GET - /automationpipeline
All users that are allowed to View the Automation Pipeline as per the permission in the interface.
